"Boing" sound when i stop
maxash0775
Bakersfield, CA
Helo all. In the last few months i have noticed a "boing" sound like a spring and my brakes click click click as i brake. Now the brakes apply fine a high speed but the sound and brake pedal feel happens at like 5mph as a brake. Has any one had this issue or heard of it? Thanks
EHmotorsports
Beaverton
steps you need to take. Jack car up, Jack stands, pull wheels off, makes sure all bolts are tightened, inspect brakes.
MellowVR4
Milwaukee, Wi
make sure the gusset plate is in place and tight, basically check if everything is tight as they said above. Have you done struts and mounts lately?
maxash0775
Bakersfield, CA
I checked the brakes and bolts and everything seems tight. Could it be the ABS since it has that feel in the pedal like when abs is activated? Stuts and mounts definitely need to be changed, just to broke atthe moment. New house kicking my arse.
