Boarderline retardation: where is my temp sensor?!
324vr4
Bozeman, Montana
I'm have my fan wired to "always on" and have eliminated the OE fan setup and have lost the OE fan switch/sensor...I need to know where I can find a OE fan switch at? Aside from a factory purchase...
iLLeffeKt vr-4
NYC
Junk yard or Jnztuning.com
I believe the sensor is located at the bottom of the radiator on the passenger side. If its no longer there what did you plug the hole with?
324vr4
Bozeman, Montana
I plugged the hole with a bolt...consequently is also duals as my rad. drain...I'd order from JNZ if they actually sent their products out when they say they would. Thanks for the advice...may check a junkyard for one...
Quoting SmoothCustomer:
I'm pretty sure it's on the driver's actually. I could be wrong though.
Nope, it's under the fan kinda by the turbo inlet, very bottom of the radiator. Passenger's side.
I believe I have one laying around, but by the time I ship it to ya, you'd might as well go get a new one from checkers or autozone.
324vr4
Bozeman, Montana
I appreciate all the advice and help...I HAVE located one from my buddy at DynoJet...will be wired in this evening...Thanks guys
SmoothCustomer
Lexington, KY
Quoting prove_it:
Damn it. I knew it was on the passengers I was just thinking about it as if I were looking at the car from the front. I said to myself "left, yeah...that's passenger's..." /ubbthreads/images/graemlins/banghead.gif
Research it and find the part number, but there's a BW temp sensor that is the same for like $9.
