belt squeal HELP!
hey guys got a minor issue here, anytime i fire up my car on a cold start i get terrible belt squeal, then it drags on into all of first gear even in boost and into second gear then when it hits about 5psi in second it goes away. then when it warms up theres no more squealing. any idea on whats wrong or replacement?
thanks guys.
Probably just need to tighten your alternator belt. Maybe need a new belt if it is old and cracked /ubbthreads/images/graemlins/dunno.gif Maybe check ps belt while you are at it.
SouthCaliVR4
North county San Diego
Fix this!!! Belt slippage will melt & separate the vulcanizing on the harmonic balancer. if the balancer fails it will go through the timing cover not come off the motor & simply pitch the belts. Alternator adjustment is easy loosen the twelve mil head bolt on top tighten the ten mil head tensioner bolt. be sure the lower bolt has not backed off or the alternator will not line up correctly. tighten both alt top & lower & your done. drop the sode cover & get a look at your balancer, paint a line across the inner & outer portions so you can see if the ring is slipping in the future, or if it looks like it has moved replace it asap. Any deviation here will affect your ability to properly time the motor as well.
