balance shaft pully removal with belts off
paul j
Lone Tree, CO
I decided to remove balance shaft pulley after everything was apart and up on stands. Any ideas how to hold the pulley to get the bolt off? I tried squeezing the belt together with pliers while holding the crank with a wrench but the pliers broke the belt.
Suggestions?
AnotherNewb
Orlando, FL
Try hitting it several times in reverse with the impact letting the pulley stop spinning in between whacks. That usually shocks it loose.
Wizardawd
Franklin, NC
Only option for the front shaft I would think at this point is to drop the oil pan and insert/wedge something against the weights to keep it from spinning.
Wiz
idreamidrive
Murray, KY
Did you www.vfaq.com ? If you just want to get it out, the breakerbar and tap starter, but you won't be able to torque it down afterwards. If you go to the timing belt section of vfaq they "show" you how to remove it and to make a tool to hold the crank from spinning so you can install it too
Edit: I suck at reading.
So it is just the harmonic ballancer? Put a breaker bar with extension on crank bolt to keep in place and get the four bolts off with ratchet.
If you are trying to do the crank bolt, then take off balancer and make tool from vfaq to hold crank in place.
