Balance shaft delete: High oil pressure?
Lonewolf64
Birmingham, Alabama
If I do the proper balance shaft belt delete with stubby shaft, I have heard that I may see dangerously high oil pressures. Is this true, or can I safely perform this mod and not worry?
chrisb33
Manila, Philippines
You will definitely increase oil pressure. You can read more about it in this thread where how to lower down oil pressure is discussed. Link
chris b
Just monitored my engine with a gauge yesterday. I removed the balance shafts and ported the housing. At cold start my OP went to right about 90, but retreated to 60 when warmed up.
atc250r
Orange County, NY
I don't think the increased oil pressure from the BS removal is anywhere near as big of a deal as it is made out to be on this board.
John
