Before i start with I got ripped off, i'll list whats been done
the following parts were changed " Everything changed or rebuilt was needed"
Transfer case
Drive shaft rebuilt
Master and Slave cylinders
Shifter Cables
All the bushings
OEM release bearing
New Fork
Rebuilt Transmission
ACT 2500 with zero miles
With that all said, i cannot make make gears. Bleed everything! Checked and double checked everything......now im guessing its internally in the trans?
Transfer case
Drive shaft rebuilt
Shifter Cables
All the bushings
OEM release bearing
New Fork
