bad egr valve equals nasty boost leak???
so my questions simple as the post says i boost checked my 926 and at less than 5psi its leaking from my egr valve i think??? can i block it off and still pass emissions? or should i just replace it
Xcelerate
Active member
North jersey
You can install a block off gasket and keep the sensor. Obd1 is usually a visual check. It won't affect your tune
1517 passed sans EGR. Mine is still physically there to pass the visual, but it is blocked off.
