axle seal
transparentdsm
Cherry Hill, NJ
Pull your axles out and you can dig the old seals out with a screw driver or a pick of some kind. Clean everything up real good and when you put the new ones in run your finger in rvt and put it on the outside of the new seal so it slides right into place. Shouldn't need any special tools, at least i never have needed them.
123abc
Winona, MN
Also, I like to use some assembly grease on the part of the seal the axle will be contacting. Helps it mate for the first time and not damage anything.
