Axle regrease?
18GVR4
snohomish, wa
I noticed a grinding noise coming from the rear, turns out there is a boot clamp missing on the rear axle. Boot is fine, but grease has been spewed out. Can a re grease be done or should it be replaced? Also, are vr4 and ggsx axles the same?
Depends. If the grease has been out long enough and the parts are worn or rusty, it may be too late. I have some spare rear axles if you need one.
