will a talon axle work i was just wondering if the 5 lug hub were different splines then the 4 lug hub and a 2g tranny will it fit on a 6 bolt ???? thanks
you asked if a 2g tranny will fit 6 bolt block and this is true BUT i think the mounts are different. not positive tho. someone confirm this if its true. i think i read it somewhere.
you can use a 2g trans in a 1g/gvr4, but not the other way around. If you use a 2g trans you will either need to modify the 6 bolt starter plate, or use the 2g starter plate. The starter lines up differently, so that is why.
