OK, I'm going to do it! /ubbthreads/images/graemlins/smile.gif I have been toying around with doing this for a while now, & since I was unsuccessfull in finding a new home for #1303 this year, it's time to build it for the SCCA DSP class & see if it can win at the National level (I think it can). I wanted to build another Miata (I have won a LOT of races in those cars) but making the Galant fast enough to win sounds fun.
The current kings of DSP are 3-Series BMWs, with the Integra Type R, Subaru 2.5 RS & a few others just a bit behind. The top BMWs of course are RWD, have about 200WHP & weigh about 2800-2900 lbs. So, the Galant looks pretty good with AWD, & should be about 280-300WHP (if set up properly) & around 2900-3000 lbs. I am pretty happy with the way the car currently handles, but I would like some better shocks/struts (I have AGXs now). Will Konis made for a 1G DSM work in our cars? The other thing I need to address is power. Per Street Prepared rules, I can run any intake & any exhaust on a stock long block, & turbo cars are allowed unlimited boost pressure. But, I have to use a completely stock turbo & wastegate assembly, as well as the BOV. Is 300WHP possible with a stock 14B & stock engine at 20+ PSI? What would the best fuel setup be to get that result, or whatever the best result possible? I currently have 650s with the big Walbro pump, would I need smaller injectors even at 20+ PSI with a 14B? Let me now what you guys think, I will try to keep everyone posted as the season goes how the car is doing! The attached picture is actually when I first built up this car. I originally set it up for DSP back then, but in those days turbo cars had to run stock boost levels. Even still, on skinny 225s (the class winners all run 285s or bigger) & only 9.5 lbs of boost I still trophied at the only National I ever entered with it /ubbthreads/images/graemlins/smile.gif
Mark
BTW, I'm looking for some stock & other parts to do this, so I created a post of what I'm looking for in the want to buy section.
Mark
