AMG cams
thomcasey
Indianapolis, IN
They are probably the same as the cams in the 150hp N/A AWD European 1g eclipse. I thought there was a small run of Lasers in the US that had that motor too?
fuel
Toronto, ON, Canada
they were hollow and high lift/high duration, which is why combined with the 10.4:1 pistons the engine made 175hp from an N/A 2L. Redline for the 5sp was 7500rpm.
AllanL
NV
You are correct.
Quoting thomcasey:
