Alternator wiring
xaisomboun
Minnesota
I bought a new Beck/Arnley reman'd alternator and my car still only runs at about 13.2 volts max and sometimes even dips down into the 9.x range randomly. I'm thinking it has to do with the black voltage regulator plug because the wires on mine seem to be mangled and burnt.
Does anyone have any idea where those wires on the plug go to? I'm planning on just soldering brand new wires onto it and route them somewhere away from all the heat.
xaisomboun
Minnesota
Correct me if in wrong but there are 3 wires going into the alternator. 1 charge wire and 2 off the plug. One wire off the plug should be a constant 12v from the battery and the other should be a ground right??
EHmotorsports
Beaverton
Correct! And I would address the connectors. What is the standing voltage of the battery right now?
My apologies I did not see the part where he was asking about the ground. Iceman is correct!
It is not a ground. the S terminal is battery voltage, the L is wired through the ignition switch and charge indicator light.
xaisomboun
Minnesota
Quoting iceman69510:
I'm assuming the S terminal is the thicker wire right? I want to re-wire the plug with new wires but I'm at a loss on where to wire them to??
transparentdsm
Cherry Hill, NJ
Quoting xaisomboun:
just cut open the wiring bundle and trace it back from the alternator. main wire goes to battery positive and on plug one is ignition relay and the other is the main relay
xaisomboun
Minnesota
Quick question! I have an APEXi pen style turbo timer with the volt meter on it and it usually reads around 12.7 volts but when I measured the voltage at the battery with the car on it was 14.2 volts.
Should I trust the turbo timer or just ignore it and buy a legit volt gauge?
