ACT twin disc?
DynastyLCD
Harwinton, CT
im wondering if anyone else has heard of this, or even tried? video is from last year. just found this today.
this could be nice, possibly a more affordable option than PTT or quartermaster? if i could even find this online for sale...
thecman02
Kalamazoo,MI
+1. I'd listen to Brian. He has been around the block once or twice. It takes ACT a while to get things right from what I've seen.
curtis
Clarksville TN
Yea being a non paid sponsored beta tester sucks. I like buying from people thats been doing the stuff forever. It maybe badass but I really can't say. Just from looks the big holes in the flywheel scare me at first glance. the amount of heat the flywheel sees is enormous and yea less weight is what there going for but I see the flywheel having to be replaced from warpage after one track season where the PTT unit will keep going .
3rdstrikedsm
32159, FL
Quoting Brianawd:
act=sh*t
ACT is flat out Garbage this has been proven over and over again! There are much better clutch options out there than this.
slugsgomoo
Tacoma, WA
those holes are very typical in v8 twin/multiplate applications, since they typically use a 5.5" or 4.5" button clutch with a flexplate, which would look like that. Either that's not a 7.25 clutch like the ptt/qm or that render is showing something a bit different, because I can tell you for a fact, there isn't that much flywheel around the outside of the clutch on a DSM when you use a 7.25".
NateCrisman
Blairstown, NJ
I'll rock that, I'v always used ACT clutches and IMHO they are the only single disk clutch that stands a chance on a dragstrip oriented car. Been using ACT pressure plates and disks since like 1997, Iv only had a couple random failures of disk springs over the years (and Iv bought and used upwards of 15 of these clutches on many different dsm/evo cars. Made like 300+ passes (many many many mid 11's) in the Evo8 with their single disk clutch and it worked awesome.
Then again, standard 2600pp will likely be fine for me until I run 9's so I won't be spending any money on a twin disk clutch anytime soon either way. /ubbthreads/images/graemlins/rofl.gif
DynastyLCD
Harwinton, CT
my ACT single disc's have all taken a hell of a beating. i dont like the new ACT stuff, all my clutches have been the old style kits. i was only curious if someone had tried the ACT twin disc.
i agree with Curtis's point about buying the parts that the old skoolers use. they use the proven stuff... so i follow their choices. theyve seen the new parts come through, and seen what stayed around.
i wouldnt go out and buy an ACT twin disc yet.... theres a PTT in my 1g for a reason!
curtis
Clarksville TN
Quoting NateCrisman:
Nate I bet a PTT would drop a half second on your ride first pass. Its freaky how much you lose from a slipping clutch you didn't realize was slipping till you install one of these.
