a pillar keeps falling
BoostedAWD91
Danville,Pa
I need some suggestions on how I can keep my dam a pillar attached. It has the clip still but factory velcro came off so it keeps popping off at the top. I've tried a few different brands of the velcro tape, super glue and nothing seems to work. It has 2 gauges on it so its getting really old every time I hit a bump it falls. Any solutions would be appreciated
381gvr4
Wakefield, RI/Meriden, CT
I had the same problem! As crazy as this sounds I used a piece of small diam rubber vacuum hose, sliced it open and place it C shaded over the plastic post on the pillar(furthest up the pillar). You need to open the metal clip to except. Give it a try! Its free!
I was thinking about this cause mine is the paulo a pillar and it does not have the bump at the end of the top tab to lock it into that clip and your rubber hose idea is so simple. Thanks for the tip, I'm going to try that. /ubbthreads/images/graemlins/grin.gif
I was also thinking that I could bond some liquid (to solid) to the end of that tab with ultraviolet light or something light. I've seen it done on plastic hearing aids but I cannot remember what chemical they used. Way more pita than the rubber hose technique though.
BoostedAWD91
Danville,Pa
Quoting 381gvr4:
Not exactly sure what you mean. Ill have to look at the pillar
steve
NJ
What could be clearer than a c-shaded hose and an exceptional metal clip? /ubbthreads/images/graemlins/hsugh.gif
cheekychimp
East Sussex, U.K.
Quoting steveGLS:
LMFAO ... /ubbthreads/images/graemlins/rofl.gif You have a gift Steve, a real gift!
beefajita
Active member
Ansonia, CT
I found provisions on the back of my a pillar covers for additional plastic clips.
I bought the !help! plastic clips for a ford @ o-reillys'; marked and drilled appropriate holes in the metal
and viola!
Also I was installing the plastics for a non-sliding seatbelt.
So get bigger clips for the additional weight, and add holes if necessary.
