A/C
Brunoboy
San Bruno,CA Home of SFO
Has anyone taken out there A/c Completely? Was it worth it? well mine doesnt work, so I have the motor out and tranny out right now on 352/1000 and Im thinking just take the whole a/c system out with the lines and condensor and all. anyone done it? j/w,
-Shane
1990ggsxnj
Blackwood, NJ
I would say that's all up to the person. Do you want it or want more engine bay space? Are you relocating the alternator in place of the a/c? We can't answer these questions for you, sorry.
Mine was gone when I got mine. Cleans things up and makes it easier to work on (which is all I do since it doesn't drive /ubbthreads/images/graemlins/mad.gif). As long as you don't mind rollin' with the windows down, then there aren't really any losses.
Brunoboy
Quoting 1990ggsxnj:
I already took out the compressor and today to take out the condensor, I just didn't want to "destroy the car",, ya know , anyways did guys removethe lines as well or just left them there? And do you guys know how much it all weighs?
-Shane
Lonewolf64
Birmingham, Alabama
I would never take a functioning A/C out of a car. It's nice to have. It sounds like you have already taken it out, so what's the question here?
Brunoboy
I haven't taken it out yet just took the compressor out , I'm wondering if anyone knows how much it weighs as q whole unit lines condensor and all
It doesn't work? Take it out.
Any weight off of a 3,500lb. car is an improvement. /ubbthreads/images/graemlins/dunno.gif
Brunoboy
ok cool, thanks guys, i know it was a stupid post that didnt make sense at the beginning, it was I just woke up, and sleep posting ahaha. does A/c removal do anything else besides weight? like better for the motor or anything?
-shane
Barnes
Richland, WA
Might help engine cooling because you don't have a condenser in front of the radiator. /ubbthreads/images/graemlins/dunno.gif
Brunoboy
Well the reason I'm probably going to take it out is because I just pulled my motor and putting another motor in, mods are mls headgasket dsm gt high flow exhaust manifold, big16g ,2g o2 housing, BSE, gates timing belt , crower springs and retainers, Evo 8 injectors and Evo 9 fuel pump, 2g intake pipe and 2g maf, jons fmic kit with Evo 8 intercooler. So does that make a difference???
Muskrat
Lexington, KY
Are you planning to DD the car? If yes, keep it in. It's nice to have, and you can't always have the windows open (hot rainy days, or really muggy days). You wont notice a huge improvement, if any.
The lines are easy to remove, the condenser is harder, because you need to pull the radiator and/or front bumper.
Muskrat
Lexington, KY
Think about it. You're losing what, maybe 20 lbs when all is said and done? The power it consumed is negligible. With the compressor idling it requires almost nothing, and with it on it MIGHT use 2 or 3 HP.
The only gain you'll probably see is slightly lower temps due to increased airflow to the radiator.
Most people remove it because:
1) The system is already broken/on it's way out, and they don't really use it anyway.
2) They use a different style radiator that they locate where the condenser used to be, freeing up space in the engine bay for working/larger turbo.
3) They're not DDing the car but using it as a race car, and every lb matters.
Or a combination of those three.
You can remove it if you want, and 9 time out of 10 you'll probably be ok without it. Just think of that one hot day, where you're driving a long way and then it starts to pour. Now you have to roll your windows up, but because it's pouring it's now really muggy in the car. Wouldn't A/C be great right now? (This has happened to me. Fortunately I no longer DD the vehicle.)
Long trips on hot days at 75mph with the windows down gets really old. I use AC in both my cars quite a bit.
What's the reason it wasn't working? Just needs a charge? I say leave it in and fix it. Unless you're building an all out race car, it's a pretty sweet accessory.
