It all depends where you have your cooler mounted. I originally had my aftermarket cooler mounted where the ABS unit is located. The lines came straight off the OFH, and then had 180* fittings to the cooler.
I had issues with leaks with the aftermarket setup, so I swapped to a stock 90 setup. It fit like factory.
