89-92 and 93-94 DSM rear calipers?
Larry Parker
Metro detroit
I have run the stock 92 rear calipers in my rally car for a while now and I need to get some new parts.... I see that 92's and 93's have a different brake pad?? Anyone know the difference in the parts? I have a set of 4 pistons brembos that I plan to use, but not until i finish my front setup... Which wont be till after STPR.... NO TIME!!
Thanks
LP
Only difference I can think of would have to do with abs.
The actual rotors and calipers are the same size and take the same pads.
edit: Fixed VR4 piston size
early 89-90 dsm pads different.
MR389566 90-94 all same. same as e39a galant vr4 too. I double checked this with actual car VINs.
1g AWD:ad35p, ~35mm piston
vr4: ad35p, ~35mm piston
1g DSM NT ABS: 30mm
1g FWD turbo: 30mm
2g FWD: 35mm piston
2g AWD: 38mm piston and ++rotor diam. this is according to the tech manual, the service manual says that ALL 2g have identical 35mm rear braking systems
joec
Westchester, NY
Maybe they changed the pad compound? Organic vs metallic? Or some sort of EPA regs that forced them to change the compound?
They should all interchange. I think there was a slight thickness change when they added shims. That is the only difference I can see in CAPS.
