501 kills another
PreskitVR4
Prescott, Northern AZ
This is 501's fourth motor with only 102,000 on the clock. She must not likey the 4G63, so this time lets try 4GCS. Anyone have a difinitve source on ALL of the cars were this motor or a FWD 4G64 6 bolt can be found? Some say that the 7 bolt 4G64 does not have crankwalk issues, but will it go into a VR4? All of the DSM stuff concerning this is really really old, and downright confusing, and with all of the pissing contests. Thanks in advance guys,
Dale
You're 100x better off rebuilding your motor with a reputable machine shop and new parts. If you keep buying used motors with unknown issues you'll keep blowing them up. After you have a new motor built make sure you have it tuned properly. A poor tune will kill a turbo motor in no time...
to use a g4cs you would have to build it anyway because the cr would be so high that running any type of boost will start to break things. get a g4cs from a sonata i forget the years but heres a good place to start researching click
if your not already a member sign up. for the most part i just read and dont ask questions cause if you ask a question trying to clear something up they tend to bitch. so post at your own risk
DR1665
Iowa City, IA
I'd say Dale has a pretty good lead on where to get his parts. /ubbthreads/images/graemlins/wink.gif
Sucks to hear about the downtime, man. That's one of the sweetest GVR4s I've ever seen.
PreskitVR4
Typically, yes, i did check... both yards /ubbthreads/images/graemlins/smile.gif
Quoting DR1665:
Street Surgeon
Omaha, Nebraska
You have my sister car, I have 501 too /ubbthreads/images/graemlins/smile.gif She came from AZ and ended up in Texas before I brought her back to NE. Good luck.
steve
NJ
1991 and 1992? /ubbthreads/images/graemlins/dunno.gif
