4WS to DSM 1g 3 bolt or 4 bolt
In order to do the swap, would I need to swap over an DSM tranny from the same car as well. From what I gathered on here is there are guys just swapping out there 4WS with a 4 bolt. But wouldnt that be the incorrect way to go about it since the final drives are different?
Terry Posten
Davenport, Iowa USA
If you get a rear end from a 5 speed car, your all set.
Auto rear ends are different ratio that 5 speeds.
So you must get a 5 speed rear and all you need to do is swap the rear diff, axles, and cups or just swap the whole subframe.
Ok thanks thats exactly what I needed to know. Also is that the same with a 3bolt from a 5 speed dsm?
524of1000
San Antonio, Tx
I may be wrong, But I think all the DSM's have the 4 bolt rears. It's only the Galant that has the 3 bolt, But like I said, I could be wrong
