3 engines in one year - do I win?
trunks
Annandale, MN
Engine number 1: Purchased here darksideracing Mar '10 - ran for 3 minutes then crapped out. Massive blowby, low compression, toast.
Engine number 2: Purchased July local DSM guy (he's in the bad guy section here too) - started horrible knocking last week. I've babied the car as a dd very rarely accelerated hard.
Engine number 3: ?? I picked up a block locally cheap. Taking it to well know builder with a good reputation. No more messing around - wiseco pistons, eagle rods, acl tri metal bearings, arp mains, l19 head studs, balance shaft removal (he's doing it for me). Anything else I'm missing? I might pick up a tre tranny too while I'm at it since 3rd gear is grinding badly. I'm also going back to an oem flywheel as I'm sick and tired of all the driveline noise from the Fidanza.
I've learned the hard way and I'm hoping any newbs reading this will learn from my mistakes. If your not sure about it don't buy it. Anybody gone through more than three blocks in a year or do I get the golden dousche award /ubbthreads/images/graemlins/bawling.gif
alansupra94
Wayne,NJ
This is why I rebuilt and build my own motors with my own clearances and specifications.
trunks
Annandale, MN
Julian unfortunately (in the bad guy section). I hate to post this as I know he's had a tough go in life in general. He's a nice guy and all but I just have to stop letting people take advantage of me.
hay dont be to hard on yourself about going thru 3 engines in one year on my old 93 ford probe in a year and a half i went thru 3 engines and trans u just gotta learn from mistakes
Diego
Purchase 1309 fall of '06
Known bad head. Replace......10.7 miles.... toast
Replace bottom end and another head.....1105 miles..... toast.
Buy a rebuilt engine...... have shop install while working out of town......3700 miles.... toast.
Spring 07 new bottom and head turbo...... 30xx.xx miles..... toast.
Fall 07 new engine.............5xxx miles, waterpump, idler pulleys, timing, oil pump lock....
Fall 08 another engine..... omg it still runs. Now to figure out the rattle/vibration coming from either trans or driveline.
trunks
Annandale, MN
I have to apologize to Julian. Looks like just a loose bolt in the timing belt arm. I think the block is okay after all.
Quoting Diego:
/ubbthreads/images/graemlins/ooo.gif
You do realize, of course, you just screwed yourself with Murphy.
KiNgMaRtY
Corona, CA
Quoting agent23:
Was it the ZE engine?
