2g pistons
mountaineerjeff
west virginia
so I got screwed on my recent buy, and am trying to get it back on the road. I have $0 of my budget left.
I was prepping the motor last night to go back together. I have everything I need to make the car run right now. however in the middle of me checking the deck my buddy makes a comment on our cereal bowl shaped pistons. I laugh, and go back to work, and he comes back a couple minutes later and gives me a new set of pistons. so I have an issue.
first I can just put the car together today and be done with it.
second is I can try and make these 2gs work. whats the cheapest way to do this, while making sure the new setup is an improvement. My buddy thinks we can get away with just buying some parts store rings. and still be better off than the unknown mileage on the rings in the motor. bearings should be reusable. but after looking into apparently im going to have issues with the oil squirters and the rod bolts? also anyone reading this feel free to let me know if you have any super cheap parts that could help out.
dsm10o0
San Jose CA
I've been researching this set up for a while now. You will need to have your 1g rods machined to accept the bigger 2g wrist pins. Some people have problems with the oil squirters hitting and some people didn't. There's a thread on tuners about it, I'll look for it and post it up.
Adorsey
mass
I have 2g pistons and made the stock oil squirters work. Its hard, but you have to hold them away (left) from where it would hit the piston while you tighten the banjo (right) they may be close, but mine looked alright. (Dont forget to check the torque spec)
Then obviously check that the stroke will not be effected, and it will do its job. I did not want to buy and wait for the Evo ones to come so I tried this and it was alright.
GL
broxma
San Antonio Tx
I haven't had any problems with my Evo pistons hitting them. However, if you are at zero dollars, the machine work, unless you can get it for free, will be probably 40 a rod.
/brox
mountaineerjeff
west virginia
the machine work I get on trade. the rings I think I got from something I sold today. plus even better is the machinist said that if it doesnt turn out exactly as it should he'll buy me a new motor....what are the issues of the rod being slightly narrow? like if they did it .050 instead of .040? just wondering how tight those clearances need to be.
IncorpoRatedX
Arizona
IncorpoRatedX
Arizona
I took that with me to the machine shop along with the pistons and rods, they took care of it for me under $100, i bent my squirters just a little and never had an issue.
mountaineerjeff
west virginia
yea, but thats not really what im asking...first I thought they had to be narrowed a 1mm which would be .040 which makes me think that the info has a misprint. or that it really doesnt matter if it is a little narrow, as long as it isnt too thick.
