2 G maf mounting?
fivestardsm
Middle, Michigan
Can a 2G maf be mounted in any position? I was thinking about running mine upside down, or maybe, on its side depending on what I do with the intake.
Dejon makes an intake pipe that mounts the 2g maf sideways, so I ASSume that would be okay. I don't know if mounting it any other way would affect it though.
fivestardsm
Middle, Michigan
Cool, so I should beable to run it upside down then! That might help me quite a bit. Also, In all theroy then, I should beable to turn the inlet and outlet vertical (straight up and down) then, correct?
fivestardsm
Middle, Michigan
^^ I did not post this to hear comments like that. If you dont have anything that is actually going to contribute to what I want to do, then please don't reply.
Thank you.
