1989 JDM VR4 power steer belt keeps getting loose
VE1337
Member
Olympia WA
Hello all, I have replaced the power steering belt after the old one became loose and started to squeal with hard steering. Even after I had the belt replaced it is giving me the same issues. Any thoughts?
VE1337
Member
Olympia WA
I can not find a support. I looked up that same image to loosen the 3 bolts. It’s moved forward to the stop. The wrong size belt must have been installed.
Dialcaliper
Bay Area, CA
In most cars, for whatever reason, using the factory service manual belt spec always ends up too tight whenever I do it that way
Loosen your P/S belt and try again to see if the squeal goes away (after double checking that your belt is the right length) The best shade tree test I’ve found is that it should be just tight enough that you can still twist the belt 90 degrees by hand. If you can’t twist that far, it’s too tight and you need to back off.
The one caveat is that using this method, you’ll probably have to go back and readjust in a 100 miles or so.
