1759 got some loving yesterday
iLLeffeKt vr-4
NYC
More than a month ago I noticed my FP Green had more play than it should. No smoke, no crazy noises (except this faint metal on metal clicking once in a while) so I decided to send it back to FP to have it rebuilt and while I was in there also went with some new hardware. I like to do stuff once so I don't have to bother every other day with crap.
New SCE copper gasket from FFWD
New ARP high grade 170000 psi alloy in a black oxide finish for turbo to manifold and o2 to exhaust housing also from FFWD. The stainless hardware is for the Tial wastegate.
New DEI Tiatnium manifold wrap which is supposed to be better than the fiberglass one, but even if its not at least I didn't itch like crazy after putting it on /ubbthreads/images/graemlins/worthy.gif
New -4AN braided stainless steel line from FP and their filter. My old line had a small spot where the stainless was shafing off.
Here's the bad boy after being rebuilt:
Turbo, o2 housing, wastegate and new o2 installed. The exhaust housing looks a bit funny from cleaning it with brake cleaner /ubbthreads/images/graemlins/dunno.gif
Everything in the car. This is my second time wrapping so I'm still practicing so please excuse the shitty job.
Fresh fluid/filter and she's ready to rock and roll:
1badgvr4
georgia
Keep checking those arp's. I used copper anti seize and checked them after the first heat cycle, and they still broke.
iLLeffeKt vr-4
NYC
Thanks. I usually check them again after few heat cycles. I also ran a tap and lubricant through the holes to make sure they're clean and not rust or anything is in there.
iLLeffeKt vr-4
NYC
Yes I'm happy with it. I've went through quite a few (14b, s16g, b16g, 18g) and drove/rode in cars with evo16g, 50trim, 57trim, gt30, gt35, and few others I don't recall right now and for what I use my car for the Green fits the bill the best.
Brianawd
Portland OR,
Next time you use exhaust wrap put it in a bucket of water and get it nice and wet. Makes it much easier to get it tight and keep it that way.
Brianawd
Portland OR,
When I did my DNP I wrapped it dry first like 3 or 4 times so that I could get the lengths right and the routing right. Then I put the wrap in water for the final wrap. I think it took me like 3-4hrs
This is how it turned out. Color should have been more bronze
iLLeffeKt vr-4
NYC
Yea I'll keep practicing with that wrap. I thought the fiberglass wrap was that you're supposed to get wet and not this one. Oh well, next time. Thanks for the advice guys.
Hksvr4
NYC
It's a good thing you wrapped it, because the exhaust side is not a good look.
jepherz
KC, Missouri
Dang, that rebuild made it look brand new. I wonder if sandblasting the exhaust would do the same.
Brian, that wrapping looks sweet!
Bead blasting the exhaust housing would make it look brand new.
This is my old FPgreen after glass beading:
iLLeffeKt vr-4
NYC
The exhaust housing was bead blasted also and the whole turbo looked brand new. However I took the exhaust housing off and ported the wastegate hole some more and then I cleaned it in the parts cleaner and sprayed it with brake cleaner. So that's why it got that white residue on it, but I'm sure it burned off by now. lol
