Where to find a replacement ECU
BLUELIGHTSBABY
Franklin, NC
Absolutely not !! Do not install a full stand alone. You will spend $1000s of dollars just for the system, possibly new wiring harness, and programming if you are unfamiliar.
You best alternative is to buy a know good galant VR4 ecu, and buy a DSMLINK chip. There is a lot of support and video tutorials on how to set it up and how to program it with your laptop. It's one of the most friendly systems that you can get for the dsms and it has been proven to put cars and the nine second quarter mile range. All for around $700 to $800. No need to chop wiring harnesses up, and you can stay on mass air or switch to speed density with just a temperature sensor and a 4 bar map sensor. Lastly you keep a lot of the Protections in place by keeping a factory ECU in charge of engine management, such as your knock sensor and other areas. I would not recommend going to a standalone
nazagalant1993
buenos aires , argentina
It is a 6A12tt engine. I don't think the ECM link is compatible with that engine. That's why I suggested a programmable ECU. You take out your old wiring and eliminate problems with the original ECU that tend to fail a lot. They are scarce in that VR4 model. You can try your luck at Japanese auctions buyee.jp
gvr4ever
central Indiana
I got my last one on eBay. A 1G manual should work in a bind. I got an eprom so I could use my tune.
As far as stand alone. I say it depends on your desired power and how much you can spend.
You can also see if http://www.dsmlink.com/ can repair what you have. They couldn't find a problem with my last one, but the car wouldn't start, until it got a different ECU. I never figured out a detailed diagnosis on the issue, so I place no blame, but they "should" be able to repair an ECU.
nazagalant1993
is a 6A12tt engine V6
Dialcaliper
Bay Area, CA
Second contacting DSMLink/ECMTuning That’s a pretty wide area of cap leakage, but there’s usually a good chance a circuit board can be cleaned and repaired, even if it requires several hours of labor and white wiring. Adapting a 3kgt vr4 might be an option but only if the wire harness is somewhat similar.
You might also ask ECMTuning if any other NA 6g72 ECU’s can be used as a core (eclipse v6/pajero, etc) if you have trouble locating a VR4 ECU
nick94vr4
Member
USA
i also have a 94 vr4. Let me know if you go with the stand alone because I too am looking into doing a swap like that. A stand alone and a tune maybe just to open the motor up a little bit more.
gvr4ever
central Indiana
Probably not worth the cost, unless you already have a larger turbo, fuel injectors, exhaust, IC if needed. I have an upgraded chip on mine to deal with all of that, but I'd need an upgraded cams, intake manifold, with a stand alone with a good tune to get a jump in power. I'm not chasing 1/4 mile or track times, so I'll never bother with the expense.
Or, if it's the only way to get a car back on the road, it would be worth it.
