Parts Out Galant Vr4 RS Monte Carlo Update Item 30 June 2025
Along Vr4
Malaysia
Good day every one.. i buy this galant vr4 e39a Monte Carlo Spec from Japan... All Item will parts out.. need anything just pm me...
NOTE : All item / parts will upload at 1st pages
Along Vr4
Malaysia
Set jdm corner, grill and headlight ( have city light ).. condition can refer picture below
Jdm corner $150 ( all tab ok )
Vr4 grill with full time 4wd badge $150 ( all tab ok )
Jdm headlight $170
Jdm foglamp $550
Seperated also can.... if take all i give $900 without paypal fees and shipping cost. Thanks
Note : All parts not with pigtail / socket... if want must add
Update : 18.6.2025
Jdm Corner
Nice condition
All tab are nice / ok without broken
bb_59912
New member
Columbia Falls, MT
I'm interested in part of the wiring harness from the engine temperature switch (B-02) with a unique 2 pin connector for the AC compressor clutch which then is combined in the split loom along with the "engine coolant temperature switch" which turns on/off the condensor fan unit (B-22-4). It also shares the split loom with the backup light switch on the transaxle (B-21) and the engine coolant gauge unit (B-01)
Along Vr4
Malaysia
Just want that sensor?
bb_59912
New member
Columbia Falls, MT
What I really need is the connector to the sensor that threads into the top of the thermostat housing as the wiring puts a load on the jury rigged parts left after the connector self destructed. Mine crumbled with age along with the now brittle wire insulation which was the root cause of my temperature gauge not working. The other engine coolant sensors and switches use spade type connectors so it was easy to replace the wiring and connections.
If you have the sensor and its connector that would be optimal as they may have used a different design than what is in my '92 VR4.
Along Vr4
Malaysia
I see... So you want that connector / socket right? I think have loose item that area.. already cut that wire...i find first... if have i put picture here or whatsapp me +60124862394
Beigetsi1990
Member
Florida
Trying to get the AC up and running for the Vr 4. Need the clip for the ac thermo switch and the plug for #3 ideally with some wire left to spice it. IMG_5679.jpeg
eubankrob1
Member
Severn, Maryland
Hi, I am interested in the interior carpet for the car and trunk., and OEM seats if possible/ in good condition. is the AC system the same on RHD/LHD cars? I would also be interested int hose parts. I am currently in the process of buying a galant vr4 and the previous owner I guess dropped alot of the interior stuff.
Along Vr4
Malaysia
Hai... that 5 pieces carpet not complete 5.. only have rear 2 pieces...Ac system JDM and USDM not same.... Seat already sold out
