JDM AC Compressor Diagram
PaulyD
New member
Bloomington, IN
So my compressor went out on my JDM vr4. I had a local VW mechanic I trust replace it. He could not get the new compressor to engage but the old one did engage but did not blow cold air. The new one blows cold air if you manually ground the clutch switch on the compressor and blows cold air. However, when it engages it puts a pretty heavy load on the motor and it wants to die at idle. Currently I have it hooked up to a toggle switch under my dash... Does anyone here have a diagram for the JDM auto climate control system? I also am curious how the "Econo" mode works and if its possible to make that still function. I noticed with the old compressor it seemed to put less of a load on the motor and obviously didnt blow as cold. Thanks in advanced everyone
FlyingEagle
THE Ottawa
Was the charge converted from R12 to R134a, because this can make a difference.
Also, are you sure the replacement compressor is identical to the old one?
There are temp sensors that can lock out the compressor clutch function when they trip .... or wires are not heading the correct way.
PaulyD
New member
Bloomington, IN
It has been converted to r134. I haven't looked myself yet at I just picked it up and drove it home, it's been a long week for me and don't have a garage ATM. I can try to snap some pictures of it tomorrow and get a model number. Mechanic said it was identical. He asked me while he was doing it if I could get a diagram, said if I couldn't he could hook it up to my old light bar switch. Which is what he ended up doing
G
zompton
I have it but it's in japanese. Do you have digital hvac or manual?
G
zompton
Sweet, was actually looking for jdm evo spec complete service manual in english as well.
misterfixit
Midlands, UK
I don't think such a thing exists.
I have the manuals in the linky in my signature. I do have others, but there are some elements that only show up in the Japanese books.
Rich
Olek.
Member
Bern
Good day.
Looking for a JDM VR-4 service manual or workshop manual. I would like to ask if anyone has a complete manual (ENG or JPN).
Thanks.
misterfixit
Midlands, UK
