226/1000 Mild Restoration Build
bobbybdemented
Active member
Magnolia, Tx
First off, my name is Robert. I have been a fan of the GVR4 since I was a kid.
I have owned 226/1000 for a few years now, working on it from time to time when I am not working on my other projects. The car has been sitting for awhile because it developed a coolant leak and the Original Owner parked it. The car is a One Owner.
Things I have done so far:
Replaced pretty much the whole cooling system and freeze plugs
Rebuilt injectors and cleaned fuel system
Installed new intake and throttle body gaskets
Some cleaning and detailing
So the plan is/was to go through the car and "fix whats broken" (there's not much broken) and resale it. So as you can see from the Pictures I have started tearing down the car to rebuild the brakes and front end. Also going to get the AC working too. Just basic stuff.
bobbybdemented
Active member
Magnolia, Tx
Oem Parts I have been collecting and some that the previous owner had stored in the trunk. I try to use oem parts when they are available.
bobbybdemented
Active member
Magnolia, Tx
So today I vacuumed down the AC system to check for leaks and it looks like there is a small leak from the valve on the compressor. I have complete O ring kit for the AC system I will tear apart the system and clean it, replace the dryer and oil it. I also did some more detailing in the engine bay.
Keeping with the " If it Ain't broke don't fix it" plan. I checked the rack and pinion for leaks and did not see any so I installed the tie rods and put new bellows on it. The original owner took very good care of this car.
I also replaced the outer cover on the driver side CV axle.
bobbybdemented
Active member
Magnolia, Tx
Been busy with other things but I got the brakes rebuilt and disassembled the struts and springs. The struts were definitely blown, as you can tell from the picture. I also dropped the gas tank.
bobbybdemented
Active member
Magnolia, Tx
So I decided to pull the head to take a look inside to see if the head needed to be rebuilt. To my surprise it looks like the head had been recently rebuilt. They also used stainless steal valves which are nice. Looks like a local speed shop named F.I.S.T Racing Rebuilt the head since they in craved there name on it.
bobbybdemented
Active member
Magnolia, Tx
Got the head cleaned and put back together. I also put a new exhaust manifold on it because the other one was cracked. And I order some 3G Revised Lifters.
While the head was off I cleaned all the AC lines and installed new O rings. I also installed a New AC Compressor. Looks like it would have been a bitch to do with intake in the way.
bobbybdemented
Active member
Magnolia, Tx
Been putting around and got all the engine pretty much put back together. I have the New front suspension together but not torqued down yet. I also starting fitting the new Head Unit. Looks like I am going to have to put a trim ring around it.
bobbybdemented
Active member
Magnolia, Tx
So I am starting to see the finish line on this project and pretty excited to drive it.
Today, I replaced the expansion valve on the evaporator and vacuumed down the AC system and checked for leaks. I also installed a aftermarket EVO 3 aluminum radiator, OEM hoses and a Spal Fan. I wanted to upgraded the cooling system because of this SE Texas Heat!
bobbybdemented
Active member
Magnolia, Tx
Finally got it on the ground and took it for a test drive. Runs Great and the AC blows nice and cold. Just got a few more things to do before she goes up for sale.
