I don't like disconnecting the battery all the time because I hate resetting my stereo presets and dash clock. Is there harm in just unplugging the ecu? I wouldn't think so but I tend to make assumptions that bite me in the ass later.
I swapped out ECU's today and nothing reset, but it was only a couple secs I think it has to be unplugged for like 5 mins and then it resets. But i've had my old vr4 in the shop b4 with out the ecu plugged in without any harm being done to it (or so i thought)
You really only need to unplug the smallest, 10-pin connector to reset the ECU. All the power connections are on those 10 pins. Within 10-15 seconds the capacitor will usually drain, and you will lose the fueltrims and other stored settings.
IIRC, I think you can also pull the dome light fuse, with the car shut down, and that will also remove the battery backup to the ECU.
Quoting keydiver:
Jeff does the 91-94 ecu's use those capacitors also if not how do you reset those sorry for the thread jack.
Quoting keydiver:
Jeff I checked both in the engine and under the dash fuse boxes and I couldnt find a dome light fuse. Am I blind(lol) or is it hidden somewhere else or labeled as something else.
It's the ten amp red fuse in position #17 of the fuse box located by the drivers left knee.
I *believe* it's labeled "room", but it's been awhile since I was in a vr4 fusebox.
If the clock loses it's time setting, you found the right one.
Quoting galant1517:
So unplugged the number 17 fuse dome light radio etc the fuel trims went back to 100% low, med and high. Took the car for a rip HT are now at 98% Med trim is at 90% and low trim is at 82% again. Guess I will have to play with the fuel pressure to fix the high trim and the mas screw to bring the low trims up or am I missing something here. The car pulls hard but I seem to get anywhere from 1-12 counts of knock before only 1-6 at wot in 5th gear. Fuel pressure is currently set at 37 psi but like Jeff said the bitch could be off so I will lower it some more.
