Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Shifter cable and bracket difference between VR4 and DSM
fivestardsm
"Savior of the damned and dis-owned"
Galant VR-4 org Post #: 837884 posted 10/07/09 07:31 PM     Remind Me!  Send Private Message   Edit Post
I had posted this a while ago in another thread to show what to look for, but I thought I would start a seperate thread just for them so here it is.
This is just to show the difference and similarities between GVR4's and DSM's with the difference pointed out about the missconception of the usage of a 90 DSM trans in a 91 model VR4 or DSM.
Just so you know, The transmission cases are the same! You can run a 90 in a 91, or vise-versa as long as you swap out the brackets and and shifter arms. The shifter arms are the only reason why the cables dont work when you do this swap.
YOU DO NOT HAVE TO CHANGE THE CABLES AND SHIFTER BASE!!!
I labled these as brackets in the picture, but ment to call them shifter arms!vv
Here are the cables sitting next to eachother. The top ones are from the VR4, the second set down, are from a 1991 and up DSM, and the third set down are from a 1990 DSM. The VR4, and 1991 and up DSM are the same. The difference in length between the 1990, and the vr4/91 up, is roughly 1 3/8 of an inch on only one of the cables. The other cable is the same length.
VR4 Picture Post
Steve.
. .27/1000 N B
.677/1000 S W
. .#?/2000 S W
.420/2000 B G
1361/2000 N B
1387/2000 N B
Posts: 1699 | From: Middle, Michigan | Member Since: 09/08/06 | IP: (68.188.223.236) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 837890 posted 10/07/09 07:55 PM     Remind Me!  Send Private Message   Edit Post
Nice post. Good info as I have a brand new set of 91+dsm cable sitting in my shed
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (166.129.128.71) | Report this post to a Moderator
maroonmetallic
VR4sRus at the old school frosty stop
710/1000
Galant VR-4 org Post #: 976315 posted 03/12/11 05:38 PM     Remind Me!  Send Private Message   Edit Post
Im bumping this up because I got sick of searching the web for hours finding conflicting info.
Despite the measurement difference in the original post, it does not say Which of the two cable sets is the longer one.
Just trying to figure out what I have/need to run my JDM (90 style) trans in my car.
-Shawn
---'92 GVR4 710/1000 (alive 8/2014)
---'12 Forester (DD)
---'92 Galant LS *gone*
---'92 Galant GSR *parted out*
---'93 Galant LS *gone*
---'93 Galant S *parted out*
---'92 Colt (63 swap) *sold*
Posts: 2084 | From: central WI | Member Since: 06/10/04 | IP: (65.25.237.185) | Report this post to a Moderator
chrisfullwood
Member +
Galant VR-4 org Post #: 994337 posted 05/20/11 11:29 AM     Remind Me!  Send Private Message   Edit Post
so the big question is.... Where can you buy the shifter arms!
Sarcasm, is the bodies natural defense against stupid.
Posts: 256 | From: bartlesville, ok | Member Since: 04/28/06 | IP: (71.153.136.43) | Report this post to a Moderator
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 994432 posted 05/20/11 06:13 PM     Remind Me!  Send Private Message   Edit Post
excellent post. this should be archived somewhere.
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (75.27.146.39) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 996338 posted 05/30/11 04:20 PM     Remind Me!  Send Private Message   Edit Post
Bump, is 91+ shifter cables all the same non turbo and turbo?
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Edited by brunoboy (05/30/11 05:39 PM)
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.145.216) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 996486 posted 05/31/11 03:39 PM     Remind Me!  Send Private Message   Edit Post
answer for this?
96 Eclipse Gsx Sold
GSNT
Deer Slayer
Galant VR-4 org Post #: 997684 posted 06/06/11 09:53 PM     Remind Me!  Send Private Message   Edit Post
MB659306 is the shift cable part number for all E33A, E38A, and E39A. All 5 speed Galants model year 1991+ have the same cables.
MB659866 is the shift cable part number for all D21A, D22A, and D27A. All 5 speed DSMs model year 1991+ have the same cables.
MD735585 is the shifter bracket that mounts to the trans for the shift cables to clip into. It interchanges with all 91+ Galants, and all 91+ 1.8, 2.0 NT, and turbo DSMs.
Posts: 520 | From: Louisville, KY | Member Since: 07/06/03 | IP: (67.163.87.214) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 998041 posted 06/08/11 01:03 PM     Remind Me!  Send Private Message   Edit Post
I was to do the same thing. I am using 90 transmission on my 91 galant I have shifting issue at high RPM. I thought may be I need to change these brack. so i ordered from dealer the lever, shaft gear shift & bracket. Part # MD729750, MD735587, MD735585. + NEW fork MD770506 & pivot ball MD719602. The rev lever is same so no need to change.
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (79.170.51.112) | Report this post to a Moderator
stella431
Galant VR-4 org Post #: 1000913 posted 06/22/11 08:44 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the Info posted along with the thread, it helped me a lot in resolving the problem.
| | | IP: (122.178.209.214) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1002828 posted 07/01/11 06:46 PM     Remind Me!  Send Private Message   Edit Post
Just got the item for 91 GVR4 to fit them on the 1g 90 transmission. Hope this will improve the shifting issue I have.
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (79.170.51.110) | Report this post to a Moderator
DarkEaglTSi
Galant VR-4 org Post #: 1052553 posted 02/20/12 02:39 AM     Remind Me!  Send Private Message   Edit Post
Soo, just to be clear...to fit the '90trans in a GVR4, I need to keep the GVR4's shifter arms and cables. Correct?
Are there any issues with the transfercase? rear diff?
| | | IP: (72.82.254.191) | Report this post to a Moderator
thedsmguy
Galant VR-4 org Post #: 1052555 posted 02/20/12 02:47 AM     Remind Me!  Send Private Message   Edit Post
You will need a 22 spline tcase to run a 90 trans. (I happen to have a lot of them for sale wink wink)
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (24.20.91.222) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1054239 posted 03/01/12 05:37 PM     Remind Me!  Send Private Message   Edit Post
It's also very easy to pull the end cover on the transmission case off, pop off the snap ring for the VCU, and swap the output shaft from a 91 trans. This is why i have something like 8 output shafts collecting dust and grease in a drawer somewhere.
I ran a 90 trans in one of my previously owned gvr4s, and all i did was change the brackets on the tranny so the car still had the 91 style. I didn't have any issue with the cable length, but IIRC, i did do quite a bit of adjustment of one of the cables at the shifter base so things would line up right.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3503 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (192.8.128.2) | Report this post to a Moderator
Galant VR-4 org Post #: 1237246 posted 05/17/17 08:14 PM     Remind Me!  Send Private Message   Edit Post
So the dsm and the Galant is the same (longer) shift arm. The one that holds the little white cube. I thought there was just a post that said it was different, but now I can't find it.
Posts: 1373 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (67.81.192.148) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1237256 posted 05/18/17 06:10 AM     Remind Me!  Send Private Message   Edit Post
They are different. Actually, both arm are I believe. You just need to match the bracket for the cables on the tranny with the arm style installed (VR4, 90, 91)
I have a 90 AWD transmission with the 23-spline output shaft installed (Car came without a transmission). I mixed and matched transmission brackets until I found one that lined up properly.
Thom
Posts: 677 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1237476 posted 05/24/17 09:00 AM     Remind Me!  Send Private Message   Edit Post
I'm not sure if this is for a 90 dsm or a Galant but it's definitely a set and definitely shorter than the 92 setup. How do I tell?
1025/2000
Galant VR-4 org Post #: 1237478 posted 05/24/17 10:42 AM     Remind Me!  Send Private Message   Edit Post
I just installed it and checked where the cable ends fell to determine which bracket I needed.
Thom
Generated in 0.087 seconds in which 0.055 seconds were spent on a total of 14 queries. Turbo powered.
