Logger not logging, video posted
James
Port richey Florida
So i just purchased a second logger, because my first one for some reason wasnt reading. i plugged in the second one and same thing, serial comm error. when i unclick pause it just cycles through everything i have highlighted to read then repauses itself.
now im thinking maybe the male pins inside my diagnostics port are wrong? Can someone take a pic of their port or something? the palm side of the plug is plugging into (if looking at the diagnostics port) top left/bottom right/second up from bottom right. does that sound correct?
James
Port richey Florida
On hold till tomorrow, on palm number2 I had the wires plugged in wrong. Will update tomorrow... Hopefully it works
James
Port richey Florida
Still a bust when i hooked it up today, i took a 2min video to show what the palm was doing and show all of my connections. for everyone who missed the previous threads...
heres the video
90 galant gsx
92 talon motor/tranny/ecu swap
dont know if wiring harness was swapped or hacked
thanks.
James
Port richey Florida
I just testing it with a multimeter, im only getting voltage at pin1, pin10 i get zero. pin12 is zero and should be since its a ground, correct?
James
Port richey Florida
Im thinking that my wiring harness was not swapped, and was just modified. because wiring for pin3 (boost) is missing on the C61 ecu plug, makes sense for that to be missing on a factory non turbo car.
James
Port richey Florida
Good luck getting help. I'm still a lost ball in high grass
Memphetic
Active member
Punxsutawney, PA
Hate to do a pitch here.. but.. if you have an Android device with bluetooth, I'm doing a group buy on MMCdroid hardware right now.
496of2000
San Diego, CA USA
The logger should work. What program are you using? The pocketlogger works from 89-94. My old fwd Laser turbo was built in 89. I bought it new June of 89. The Pocketlogger required a passcode to access the software on the palm3xe.
496of2000
San Diego, CA USA
Quoting Hondasi88:
im in the same boat...no connection here is a pic of my setup
This loggeer looks like its for OBD2.
EHmotorsports
Beaverton
You can see the notch in the connector. It is for a dsm or galant.
Hondasi88
MD/NOVA
Like someone else mentioned, checked your connection on your port. Mine had a few bent pins but after getting all those sorted out my logger setup finally works.
James
Port richey Florida
This has been solved. I got a second diagnostics port and I wired it in right at the ECU. Works perfect.
