FS: Liquidating Parts; High Quality; SOMETHING FOR EVERYONE *Updated 3/9*
JSchleim18
Long Island, NY
*ALL PRICES ARE SHIPPED PRICES UNLESS NOTED; CAN SHIP WORLDWIDE*
**PLEASE ADD 3% FOR PAYPAL TRANSACTIONS (CONVENIENCE FEES)**
***PAYPAL IS [email protected]***
PICTURES HERE: click
GVR-4 Specific:
GVR-4 USDM Rear Bumper Lights (used) - $20
GVR-4 Eco/Power Switch with pigtail (used) - $20
GVR-4 JDM Dash Mat (used) - $50
GVR-4 BoostX Lip (NEW) - $200 PLUS SHIPPING
DSM/GVR-4:
14mm? OEM Copper Crush Washers - $3
Mitsubishi Turbo Coolant Line Plugs - $5
OEM Exhaust Manifold to Turbo Washers - $8 for all
Delrin Shifter Bushings - $20
1G/GVR-4 Rear Trailing Arm Bushings (OEM, 100k on them. Still in great shape) - $20
1G/GVR-4 Rear Motor Mount bracket 195B (used) - $20
1G/GVR-4 Noltec N62168 Trailing Arm Bushings (NEW) - $30
1G/GVR-4 Superpro SPF1439K Trailing Arm Bushings (NEW) - $30
2G AWD Trans mount with poly mount installed (used) - $30
Taboo Speed Shop Shifter Bushings (NEW) - $25
OEM Mitsubishi Rear Brake Pads (NEW) - $30
OEM Power Steering Pump Rebuild Kit (NEW) - $30
6 Bolt Non-Turbo Block (100K miles; virgin) - $100 PLUS SHIPPING
1G/GVR-4 Shifter Cables with bearings already pressed in (40 miles on them) - $150
1G/GVR-4 Willwood Brake Kit (used; designed for use with wheels 16" and over. Complete with pads, rotors, calipers, and lines) - $600
Universal:
2.25" t-bolt Clamp - $5
-10 AN Stainless Braided Line - $8
GReddy Type RS VTA adapter - $10
NGK BPR7ES Spark Plugs (two sets of 4) - $10 each
-8 AN Straight Fittings - $10 each
-8 AN 90* Fitting - $15
ATE Brake Fluid (Type 200 and Super Blue) - $10 each
Red Line Power Steering Fluid x2 - $10 each
Yellow Fog Light Inserts (NEW) - $50
Two (2) Dunlop Wintersport M3 Tires (205/55/16; Used for 3,000 miles) - $100 PLUS SHIPPING
Halguard HG250R Halotron Fire Extinguisher (NEW) - $125
Bell Sport Mag Size Small SA2005 Helmet + Bag + Extra Visor (NEW) - $200
OMP WRC Suede Steering Wheel + OMP Mitsubishi Hub Adapter (NEW) - $300
SOLD:
Hogan (Extreme Motorsports) Intake Manifold - $350 **SOLD**
JNZ GVR-4 Short Shifter (NEW) - $125 **SOLD**
3000GT VR-4 Calipers (used) - $100 **SOLD**
OEM MLS Headgasket (NEW) - $110 **SOLD**
Porterfield R4S Brake Pads Front and Rear (NEW) - $120 **SOLD**
Magnecore Spark Plug Wires (used) - $50 **SOLD**
OEM Clutch Slave Cylinder (NEW) - $50 **SOLD**
Energy Suspension Front Subframe Bushings Black - $20 **SOLD**
JDM Fuel Door (used; white) - $50 **SOLD**
Two (2) BLE Solid Lifters for camshaft adjustment (NEW) - $50 **SOLD**
JDM Door Handle Scratch Protectors (used) - $70 **SOLD**
Engine Bay Plastics (used) - $60 **SOLD**
Evo Valve Springs and Retainers (4,000 miles) - $80 *SOLD*
OEM Chrome Trim for Bumpers (NEW) - $80 **SOLD**
1G Cam Angle Sensor (used) - $20 *SOLD*
3G Eclipse Brake Master Cylinder - $60 *SOLD*
Walbro 400LPH Fuel Pump + Universal Install Kit (NEW; for big HP or E85) - $150 *SOLD*
Galant VR-4 transmission - $225 **SOLD**
4G63 Crank (100K miles; virgin) - $150 **SOLD**
Fuelab -6 AN Fuel Filter - $110 **SOLD**
FIC 1350cc BlueMax Injectors - $300 *SOLD*
GVR-4 Mitsubishi Valve Cover - $40 *SOLD*
JMF Coil Pack Relocation Bracket - $40 **SOLD**
2G Coil Pack (used) - $20 **SOLD**
FP 2.5" Stainless Steel o2 Housing with dump tube (NEW) - $220 **SOLD**
Evo 3/RVR Coil Pack + Bracket (used) - $50 **SOLD**
Russel -6 AN Proclassic Hose (NEW; 15 feet) - $65 **SOLD**
FIC 850cc Fuel Injectors (NEW; Includes new easy disconnect pigtails) - $220 **SOLD**
Fiberglass GVR-4 Trunk (NEW) - $270 **SOLD**
Cusco Front & Rear GVR-4 Strut Tower Bars (Lightly used) - $280 **SOLD**
Evo Rocker Arms (lighter than stock) - $100 *SOLD*
DBA 4000 Slotted Rotors for 5 lug setup (front; NEW) - $200 *SOLD*
GVR-4 Driver Side Kick Panel (mint) - $20 *SOLD*
Scroth Rallye 3 Harnesses - $225 *SOLD*
OEM o2 Housing Bolts - $5 for both *SOLD*
1G/GVR-4 OEM Dipstick (NEW) - $15 *SOLD*
ECU Plugs (used) - $30 *SOLD*
Flaming River FR1006 Battery Disconnect Remote Lever Mounting Kit (NEW) - $60 *SOLD*
GVR-4 JDM Door Handle Scratch Protectors (NEW; Replicas) - $60 *SOLD*
Magnaflow 12198 Muffler + Summit Racing 2.5 to 3" Polished Tips (NEW) - $150 *SOLD*
GVR-4 1993 Grille (used; black) - $60 *SOLD*
Street Surgeon
Omaha, Nebraska
Interested in the O2 housing, want to see what it looks like.
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
I'll take the used door handle protectors. LMK.
JSchleim18
Long Island, NY
Quoting Street Surgeon:
which one?
hogan manifold is at work. I will get pics of it Monday.
Is that turbo supposed to be the HTA GT3076R? Because I dOnt see any HTA 3176 on their site. Can u post pics of it?
Gizmovr4
andover,NJ
pm sent
maroonmetallic
central WI
Quoting omertaitalia:
is the 93 green grill belize?
It shouldn't be. If its OEM paint its a darker color than belize.
dustyduff
Mantua, NJ
I'll take a 93' grille if you have one without any broken tabs. I'm not too concerned about the color. Pm me with details. Shipping to 08051.
988
Malaysia
PM sent
JSchleim18
Long Island, NY
</font><blockquote><font class="small">Quoting GSX_TC:</font><hr />
It is a non-ball bearing 3076 with a billet compressor wheel. It spools just as quickly as a ball bearing turbo but doesn't recover as quickly between shifts. It is also oil cooled only (no need for water cooling) and cheap as hell to rebuild.
From FP:
"It is a new turbo we have not offered before, very similar to an FP3160 we have offered in the past, but with our 76HTA™ compressor wheel. Uses the T31 turbine center section and is a T3/T4 hybrid style turbo. It is a journal bearing/dry bearing CHRA meaning it has no water ports, so you will not run water lines with this turbo, it is oil cooled only.
This turbo does use the same compressor wheel found on our FP GT3076HTA™ Turbo, the biggest difference being that turbo is a BB and the 3176HTA on sale is not. If you have any other questions, please let me know!
This turbo is more comparable to the 3052, but actually falls in between the 3052 and 3065:
FP3052 = 52lb/min
FP3176HTA = 59lb/min
FP3065 = 65lb/min
Both the FP3052 and FP3065 use the standard Garrett cast compressor wheels where our FP3176HTA uses the 76HTA billet aluminum compressor wheel."
Thanks for the info
988
Malaysia
Quoting JSchleim18:
Picture of green grille: click
Thanks jeremy....... /ubbthreads/images/graemlins/wink.gif
JSchleim18
Long Island, NY
Quoting acustark:
Will the chrome trim fit the JDM bumpers?
Yes...they only sell the bumper trim for the rear bumper (since it is the longest). but it is cut to fit for the front bumper, JDM bumpers, and door skins.
Also, it is sale pending locally.
alansupra94
Wayne,NJ
Got any pictures of that Hogan Intake? Also what is it flanged for throttle body wise? Very interest and can pick up as well.
