Your talking about the inner panels right?
Remove all screws. There are screws holding the door handle cover on, 2 holding the door pull on, 1 behind the ash tray (rear doors), a few around the sides and bottom.
Then slide the whole skin up. It has catches along the top where it trims down into the window well. DON'T pull the bottom outward. You will rip the press-board where the lower slide clips are.
Once you have it slide up about 1", then just pull away from door and unplug the lights and route the window switch harness through the hole.
