Timing belt time
bobdole
U.K.
Will be doing my timing belt on 504/2000.
Just want to confirm part numbers and what I need.
I also seen the OEM water pump is the same as Aisin WPM-012. Is this correct ?
Thanks in advance.
boostme
Crete, IL
Yes, I believe Aisin is the OEM brand to Mitsu. I'll be using a Gates belts/water pump setup BUT with a OEM tensioner.
If it was a stock motor I would use the Gates Tensioner. But I have a couple pretty pennies in my motor so OEM it is.
bobdole
U.K.
Cheers Boostme.
GotInsulin
Philly burbs
Yep, the Aisin pump is the same as Mitsu just with no Mitsu part number. I've used a handful of them over the years with great results. $50 trumps $150 every time.
