Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Ig gsx sway bars on a gvr4
Wolfdsm
Galant VR-4 org Post #: 991699 posted 05/08/11 04:07 PM     Remind Me!  Send Private Message   Edit Post
Will 1g gsx sway bars fit on my galant vr4??
| | | IP: (67.87.145.15) | Report this post to a Moderator
donkeylips
Swapped Female Parts
924/1000
108/1000
372/1000
Galant VR-4 org Post #: 991743 posted 05/08/11 08:35 PM     Remind Me!  Send Private Message   Edit Post
As far as I know, as long as you don't have any of the 4WS components anymore. If you have the 4WS rear pump or rack you need one from a gvr4.
1990 Nordic Blue Galant GSX, A71 KG 372/1000
A72 KG 108/1000 & A72 BG 924/1000 - Both Rotted
93 Mirage, 92 TealSI AWD, 85 200sx, 87 Trans Am
Posts: 552 | From: Rochester, NY | Member Since: 06/19/09 | IP: (128.205.74.185) | Report this post to a Moderator
Galant VR-4 org Post #: 991766 posted 05/08/11 10:25 PM     Remind Me!  Send Private Message   Edit Post
Rear might work if you have no 4WS as stated, pretty sure the front will not.
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (116.48.14.59) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 991769 posted 05/08/11 10:34 PM     Remind Me!  Send Private Message   Edit Post
Actually the front is a no problem fit & again without four wheel steering the rear fits as well.
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (76.176.152.126) | Report this post to a Moderator
Galant VR-4 org Post #: 991775 posted 05/08/11 11:04 PM     Remind Me!  Send Private Message   Edit Post
We are talking about a DSM GSX not a Galant GSX right? If so I would appreciate it if I could send you a photo for some advice because I bought a DSM swaybar off a member here that was supposed to fit the VR4 and it's not even close.
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (202.140.110.32) | Report this post to a Moderator
donkeylips
924/1000
108/1000
372/1000
Galant VR-4 org Post #: 991796 posted 05/09/11 12:23 AM     Remind Me!  Send Private Message   Edit Post
Are you talking front or rear? Front should definitely fit, rear won't if you still have 4WS components.
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 991804 posted 05/09/11 01:40 AM     Remind Me!  Send Private Message   Edit Post
Quoting cheekychimp:
yes dsm, fits. yours should have fit unless there's some jdm difference I am not aware of.
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 991828 posted 05/09/11 07:40 AM     Remind Me!  Send Private Message   Edit Post
I have ST swaybars on my vr4 that came off my Talon. So yes they do fit. The back will not fit if still have aws
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (134.134.137.73) | Report this post to a Moderator
Galant VR-4 org Post #: 991862 posted 05/09/11 09:42 AM     Remind Me!  Send Private Message   Edit Post
Mmmmm that was what I had been led to believe too. Like I said I guess I need to post up a picture of the bar to confirm it is a DSM bar first.
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (202.140.110.25) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 991919 posted 05/09/11 02:02 PM     Remind Me!  Send Private Message   Edit Post
Are you sure its not a 2g dsm bar?
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (192.55.55.39) | Report this post to a Moderator
Galant VR-4 org Post #: 992037 posted 05/10/11 01:53 AM     Remind Me!  Send Private Message   Edit Post
Distinct possibility. I may have fucked up through having insufficient knowledge of the USDM models. How would I identify a 2G bar? Are the ears twisted 90 degrees?
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (202.140.110.33) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 992050 posted 05/10/11 02:24 AM     Remind Me!  Send Private Message   Edit Post
Cheeky, front or rear?
| | | IP: (74.82.64.33) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 992051 posted 05/10/11 02:29 AM     Remind Me!  Send Private Message   Edit Post
I've seen FWD 1G's with front bars and front control arms that utilize a bolt style endlink instead of the dual ball joint style endlink.
Galant VR-4 org Post #: 992062 posted 05/10/11 04:12 AM     Remind Me!  Send Private Message   Edit Post
Yeah it is a front bar. That's interesting about the FWD bar. Could it be made to work or alternatively would it fit a FWD Galant like the GTi?
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (202.140.110.35) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 992531 posted 05/11/11 08:01 PM     Remind Me!  Send Private Message   Edit Post
I'm taking shots in the dark here, but I'd imagine you could utilize a rear swaybar end link, just turned upside down. The ball portion of the link would attach to the control arm, and the bolt portion could attach to the bar itself. One question though, is this bar that you have an upgrade? Because stock FWD 1G bars are only 19mm diameter, while AWD 1G and VR4 front bars are 20mm. It may not be worth it if the bar is stock...
Another thought, the VR4 front bar has a slight "u" shaped bend in the center of it so the driveshaft has clearance to go underneath. I'm not sure if a FWD bar will have that.
Any how, it should be good to run on a FWD galant, you may have to get creative with the link depending on the type of control arms being used, but the bar should be shaped correctly otherwise.
Edited by galant1517 (05/11/11 08:07 PM)
| | | IP: (74.82.64.37) | Report this post to a Moderator
Galant VR-4 org Post #: 992624 posted 05/12/11 06:57 AM     Remind Me!  Send Private Message   Edit Post
It's supposed to be an upgraded bar, I thought actually it was an ST bar but I'll have to check and get a picture, I'm sure that would help. I am also pretty sure that it has a part number on it.
Edit: Okay it is supposed to be an ST bar. I found the old for sale thread with a link to the bar that I was supposed to get and I thought it looks very similar to what I got but I just called Ken and he says this bar is nothing like the stock one. I obviously need to go and get a photo of my actual bar and post it up to compare it to see if I got sent the wrong one. Are the endlinks different on a DSM? It also says FWD and AWD bars are the same.
Sway Bar Link
Edited by cheekychimp (05/12/11 07:19 AM)
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (223.130.39.151) | Report this post to a Moderator
Wolfdsm
Galant VR-4 org Post #: 994809 posted 05/22/11 04:28 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help everyone
1 registered and 4 anonymous users are browsing this forum.
Generated in 0.196 seconds in which 0.168 seconds were spent on a total of 14 queries. Turbo powered.
