Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Help replacong rear axle bearings.
Vince
1212/2000
Galant VR-4 org Post #: 1244607 posted 11/12/18 05:05 PM     Remind Me!  Send Private Message   Edit Post
Just another delay that is slightly annoying.
I have new Rear axle bearings and hub assembly.
Looking at the shop manual, (and other FWD cars I have done) it is a straight forward job.... Until I pull the rotor, and see there is no axle nut or washer. Just a solid unit with no visible method of being retained. Is the OEM assembly meant to be press fit?
Seems odd to me, so I hope someone will help out before I go renting pulling tools and such
Seeing that the Moog assemblies didn't come with a axle nut and washer, I hope my local parts store can get them.....
Domo Arigato (thank you)
VInce
Resurrecting Nile Black 1212/2000
Edited by Vince (11/12/18 05:05 PM)
Posts: 59 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (174.21.4.237) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1244608 posted 11/12/18 07:43 PM     Remind Me!  Send Private Message   Edit Post
They are press in. There is an inner and an outer. The inner bearing usually stays on the axle cup spline.
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
Vince
1212/2000
Galant VR-4 org Post #: 1244609 posted 11/12/18 09:14 PM     Remind Me!  Send Private Message   Edit Post
OK, Thanks... I think...
So here (see link) is the replacement
It has both inner and outer bearings, so if I understand correctly, a slide puller will separate the existing hub from its mounting without further disassembly on the back side of the trailing arm. Correct?
I assume that when the hub comes out, the axle shaft will remain in place so the new unit can be driven back in? Is the original axle shaft end threaded so that the new unit can have a washer and castle nut installed to secure it?
Tanks again
V
Posts: 59 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (104.128.136.42) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1244612 posted 11/13/18 06:19 AM     Remind Me!  Send Private Message   Edit Post
That looks like a FWD rear hub assembly. The AWD assembly has an axle shaft built into it that bolts on the inside of the axle cup. Also, the outer bearing normally stays on it and has to be removed, the inner bearing will need pressed in/out. Here is a pic of them and a link to a set for sale. The bearings and inner seal can be found on RockAuto.
PerformancePartout
Thom
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1244613 posted 11/13/18 08:00 AM     Remind Me!  Send Private Message   Edit Post
Yes, you have FWD brearings. Looking at Tom's provided photo, you can see that you need to remove the rear axle shafts and get to the 22mm (I believe) nut to be able to tap that complete stub axle assembly out to replace the bearing.
see this thread for good instructions: How to
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10606 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Vince
1212/2000
Galant VR-4 org Post #: 1244615 posted 11/13/18 12:51 PM     Remind Me!  Send Private Message   Edit Post
Awesome...
Well, kinda, cause i gotta return and reorder.
Thank you all for your advice and words of wisdom.
Vince
Vince
1212/2000
Galant VR-4 org Post #: 1244817 posted 12/07/18 12:03 PM     Remind Me!  Send Private Message   Edit Post
Sigh......
Well after that fiasco, it turns out the correct rear hub assembly is no longer available from Mitsu.....
That leaves me with just having the bearings replaced, which I cant do myself... grrrrr
Before I go to the WTB section, do any of you know of a source outside Mitsu that might still have the complete unit available, of offer rebuilt ones?
V
Posts: 59 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (192.200.24.13) | Report this post to a Moderator
Galant VR-4 org Post #: 1244818 posted 12/07/18 01:51 PM     Remind Me!  Send Private Message   Edit Post
Still a little confused by your posts. Even if Mitsubishi still sold the rear hub, it would not have the bearing on it as a service part. They would have to be installed. Typically, this type of part is never offered by the aftermarket.
There are ways to change them at home in the shop, you just have to be a bit creative on removal and pressing them back on. I have done it before.
Vince
1212/2000
Galant VR-4 org Post #: 1244819 posted 12/07/18 03:11 PM     Remind Me!  Send Private Message   Edit Post
Thanks Iceman
Mitsu actually sold the whole assembly (MB569254), hub, bearings, gear, back flange and all (about $200/ea). This was my preference as I can accomplish a swap without serious effort.
Now seeing that the assembly is no longer available, I'll have to resort to replacing the bearings and seals on my existing hubs, (and hope the gear is in good condition). This isn't something I can do in my current condition.
Instead,, if no one offers a 'rebuilt', then I will hit the WTB section for a pair, buy the bearings and seals, and present them to my local shop to do. I can still drive while that is being done.
Once those are made serviceable, I can fall back once again to simply pulling and replacing the failing ones on the car.
V
Generated in 0.219 seconds in which 0.193 seconds were spent on a total of 14 queries. Turbo powered.
