Stock GVR4 rear axles the same?
I am shocked I don't know the answer to this off the top of my head (or I have forgotten...), but are the rear stock axles the same Left and Right? I have a pair sitting here and I can't tell the difference. I have searched here and not found anything confirming or denying it explicitly. To be clear, I am asking about 3 bolt non-LSD, as I know the answer for other (non-stock) versions.
I did check CAPS and I see the left/right shaft repair kits are the same part number. The version I was using (on-line) does not seem to show assemblies anymore to check those part numbers.
Thanks.
Near Seattle, Washington
Yes. Open diffs have the same axle on both sides. Only the LSDs have one axle with a 2nd set of splines.
Thank you sir.
