Galant VR-4 Forums » Galant VR-4 » Technical Discussions » couple vacuum line questions with pics 92 Galant
scottinalaska
676/1000
Galant VR-4 org Post #: 1233474 posted 11/15/16 11:40 AM     Remind Me!  Send Private Message   Edit Post
I just purchased a VR4 and love it. Previous owner lost his balance shaft belt and....yeah, lost the rest. So now it is balance shaft deleted and EGR and A/C deleted. No CE lights and it runs well. No ABS light, boost is strong, etc.
But I have a few items that don't seem resolved. A little direction here would be appreciated. I have circled the mystery parts. Like where does this bracket connect to and plug into?
Thanks,
Scott
Posts: 47 | From: Alaska, USA | Member Since: 11/15/16 | IP: (24.237.106.213) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1233477 posted 11/15/16 11:51 AM     Remind Me!  Send Private Message   Edit Post
1st pic looks like old connections for the now deleted AC system. and fan assembly
2nd pic looks like the large line that game from the EGR Canister back to the intake (plug the intake side)
3rd pic is your Blow-off valve. The small vacuum line connects to the line coming out of the intake manifold
Posts: 803 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
scottinalaska
676/1000
Galant VR-4 org Post #: 1233496 posted 11/16/16 12:41 AM     Remind Me!  Send Private Message   Edit Post
Thank you for the picture example. I already have that intake spot taken. Is this right? I also have another similarly acting vacuum on the valve cover to the left. This leaves my Blow Off valve hanging. The car runs excellent with no lights on. The turbo is smooth and doesn't give any indication of problems. But this Blow Off valve is really a diverter valve, right? I mean, it doesn't blow off to the atmosphere or exhaust. It just shuffles it right in before the turbo.
Thus, maybe I need to find a different intake manifold vacuum nipple? Or like I noted a few sentences ago, is the spot you circled going to the wrong place?
Thanks!
scott
138/2000
Galant VR-4 org Post #: 1233497 posted 11/16/16 12:53 AM     Remind Me!  Send Private Message   Edit Post
look straight down from the T in MULTI, there is a capped vacuum port. that goes to the BOV. the hose to the intake tube is fine. the other one is fine to, but you'll want to zip-tie it at the valve cover port and get a one-way/brake check valve for the hose and make sure no air can flow into the valve cover.
138/2000
Edited by transparentdsm (11/16/16 12:56 AM)
Posts: 3500 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1233499 posted 11/16/16 07:14 AM     Remind Me!  Send Private Message   Edit Post
Yea, seems I grabbed a pic of an NA intake manifold.
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
scottinalaska
676/1000
Galant VR-4 org Post #: 1233534 posted 11/17/16 02:03 AM     Remind Me!  Send Private Message   Edit Post
Transparen,You reference the Multi. I do not know what that refers to.
Here is a pic of a multiple of capped nipples.
Also, should I cap this tube that I presume used to go to my cannister?
Thanks,
scott
866/1000
Galant VR-4 org Post #: 1233536 posted 11/17/16 06:23 AM     Remind Me!  Send Private Message   Edit Post
Look where it says ECI MULTI on you intake manifild. Look down from there and you will see a small vacuum nipple sticking out, that is where the BOV connects to.
Quoting scottinalaska:
Thanks!
scott
Thom
scottinalaska
676/1000
Galant VR-4 org Post #: 1233682 posted 11/22/16 12:52 AM     Remind Me!  Send Private Message   Edit Post
Transparent and Thom,
Thanks for VERY detailed description you gave me. It was so good, I didn't even get it! The LETTER "T"! You were certainly dotting your i's and crossing your T's there.
That is now taken care of along with a oneway valve.
Any thoughts on my orphaned fuel line from the tank that sits wide open down near the ground?
Thanks,
Scott
138/2000
Galant VR-4 org Post #: 1233683 posted 11/22/16 03:04 AM     Remind Me!  Send Private Message   Edit Post
There used to be a charcoal canister there, just leave it open, it's a vent tube for the tank vapors.
138/2000
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.22 seconds in which 0.191 seconds were spent on a total of 14 queries. Turbo powered.
