Galant VR-4 Forums » Galant VR-4 » Technical Discussions » is this a symptom of crankwalk or a frozen throw out bearing?
ercp98
perpetual n00b
1148/2000
Galant VR-4 org Post #: 1232226 posted 10/02/16 11:16 PM     Remind Me!  Send Private Message   Edit Post
Good evening,
Please see attached video.
The noise goes away or seems muffled when i depress the clutch pedal.
Then I tried something I read on dsm tuners, rev the car to 2k and depress the clutch pedal, the rpm did go down but just a little.
Also you can see in the video that at idle, the car dies as soon as I depress the clutch.
My clutch is an old ACT 2100. I also felt clutch slippage a few days before these symptoms were manifested.
I also tried to visually confirm if the crank pulley would move when the clutch pedal was push in. I did not see any noticeable movement on the crank pulley.
Can these "symptoms" be cause by a dying clutch and an old TOB that is frozen and does not spin anymore?
Thank you in advance for any advice and suggestion.
video link:
Posts: 1329 | From: northlake in illinois | Member Since: 08/05/03 | IP: (2602:306:36fe:84) | Report this post to a Moderator
donniekak
Member ++
Galant VR-4 org Post #: 1232227 posted 10/03/16 12:16 AM     Remind Me!  Send Private Message   Edit Post
It's probably the throw out bearing. To check for bad crank walk grab the crank pulley and push and pull on it. If it's walked bad you'll feel the movement, and hear it clicking or knocking back and forth.
Posts: 747 | From: surprise az | Member Since: 01/01/09 | IP: (97.124.17.161) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 1232230 posted 10/03/16 03:52 AM     Remind Me!  Send Private Message   Edit Post
I believe max is like 8 thousandths .....get a dial indicator to check for the crankwalk
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11891 | From: Clarksville TN | Member Since: 05/04/03 | IP: (172.68.78.156) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1232235 posted 10/03/16 06:33 AM     Remind Me!  Send Private Message   Edit Post
A flexing shift fork can fake crankwalk symptoms. I remember many moons ago when I was on the original and a ACT 2600 clutch, I would go around a corner and I would have a odd delay of clutch action on the release.
I'd imagine it could be anything that would involve clutch release. Fork, TOB, damaged clutch forks, or even running out of friction material. I have never in my life worn out a TOB before a clutch, so that would be a neat trick.
1992 Nile black w/sunroof
Posts: 5826 | From: central Indiana | Member Since: 08/06/02 | IP: (172.68.59.44) | Report this post to a Moderator
donniekak
Member ++
Galant VR-4 org Post #: 1232239 posted 10/03/16 08:48 AM     Remind Me!  Send Private Message   Edit Post
Quoting curtis:
That is the spec I go by when building engines. But for a car to show symptoms, especially a 1g engine with no crank sensor, the play is usually at least 1/16" and you can physically feel it.
ercp98
perpetual n00b
1148/2000
Galant VR-4 org Post #: 1232240 posted 10/03/16 09:14 AM     Remind Me!  Send Private Message   Edit Post
thank you guys.
i will try and get a dial gauge and get a measurement.
but for now that the engine is still in the car, can i just physically
pull on the crank pulley and check for movement? do i need the
accessory belts off to do this?
Posts: 1329 | From: northlake in illinois | Member Since: 08/05/03 | IP: (2600:1008:b106:4) | Report this post to a Moderator
donniekak
Member ++
Galant VR-4 org Post #: 1232248 posted 10/03/16 06:45 PM     Remind Me!  Send Private Message   Edit Post
I'm still betting on your tob. To check for crank thrust play its best to at least take the tension off the acc belts.
ercp98
perpetual n00b
1148/2000
Galant VR-4 org Post #: 1233007 posted 10/30/16 10:10 PM     Remind Me!  Send Private Message   Edit Post
just an update and to add a resolution for future reference.
there is no crank walk. confirmed with dial caliper.
this turned out to be a frozen throw out bearing and a slightly bent fork.
all parts replaced.
thanks for all the advice.
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.109 seconds in which 0.089 seconds were spent on a total of 14 queries. Turbo powered.
