Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 2G MAF issue
2G MAF issue
GTX
Galant VR-4 org Post #: 1229799 posted 06/28/16 08:57 AM     Remind Me!  Send Private Message   Edit Post
Hi gurus,
Just wanted to pick your brains, may be someone had similar issue. The engine quit on a very hot day (well, we were running it quite hard to be honest). Symptoms of running on 3 cylinders, but with no power whatsoever. It appeared to be a MAF supplying twice as much frequency to ECU. Say, instead of 50-60 Hz at 1200 RPM it would tell 150 Hz. Engine was running too rich. Disconnecting the MAF fixed the idle (ECU goes into default mode), obviously MAF has to be replaced. However, has anyone of you played with MAF internals? I mean the board itself, may be it has some known weaknesses? Capacitors, not heat-sink for the transistors and etc?
Cheers
A
1991 Galant VR4 RS Rally
2005 Subaru RS 2.5
2013 Honda Accord EX V6
2017 Honda Ridgeline EX
Posts: 93 | From: Toronto, Canada | Member Since: 04/13/12 | IP: (108.168.26.208) | Report this post to a Moderator
0 registered and 25 anonymous users are browsing this forum.
Generated in 0.096 seconds in which 0.088 seconds were spent on a total of 14 queries. Turbo powered.
