Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Blowby issue, now pissing smoke from breather & exhaust
sixcentz
Newbie
Galant VR-4 org Post #: 1225433 posted 03/10/16 07:22 PM     Remind Me!  Send Private Message   Edit Post
Hi I have a 1990 VR4 that's been blowing oil out of the dipstick though has now begun blowing constant white smoke out of the valve cover breather as soon as the engine is turned over, under acceleration there is huge clouds coming out of the exhaust (did look blue from what I can remember)
The guy I got the car off had the engine fully rebuilt with forged pistons only around 4000kms ago.
Any suggestions on what it could be are very much appreciated though I am guessing it needs another bottom end rebuild
Compression test came out as 180 180 120 180
Cheers
Posts: 4 | From: NZ | Member Since: 11/17/15 | IP: (118.92.133.94) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1225449 posted 03/11/16 09:45 AM     Remind Me!  Send Private Message   Edit Post
Seems to me like you have a valve guide issue.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1634 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.11.233.34) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1225459 posted 03/11/16 05:08 PM     Remind Me!  Send Private Message   Edit Post
I had a very similar issue. It was a cracked/heavily damaged ringland.
Ryan W.
Posts: 440 | From: Granby, MA | Member Since: 09/27/06 | IP: (73.142.6.86) | Report this post to a Moderator
Dale
Newbie
Galant VR-4 org Post #: 1225461 posted 03/11/16 07:16 PM     Remind Me!  Send Private Message   Edit Post
Quoting sixcentz:
Cheers
On the cylinder with low compression, did you do the oil test. Add a cap full of oil to cylinder & see if compression rises. If it rises it's usually a sign that the rings are bad. Can others confirm or agree with this.
1990 Aus Spec HH vr4
Jap Spec 4g63 Built Motor
Posts: 13 | From: Brisbane, QLD | Member Since: 06/18/14 | IP: (101.183.135.168) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1225478 posted 03/12/16 12:40 PM     Remind Me!  Send Private Message   Edit Post
White smoke is indicative of water/coolant in the oil. I would do a leakdown (cams out) first, especially on that cylinder with 120psi. Anything else right now is guesswork.
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 240 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (69.174.87.60) | Report this post to a Moderator
89Patches
I <3 AMS
Galant VR-4 org Post #: 1225508 posted 03/13/16 06:59 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbofonz:
^^ This
Posts: 723 | From: Ontario Canada | Member Since: 01/30/13 | IP: (174.35.243.172) | Report this post to a Moderator
sixcentz
Newbie
Galant VR-4 org Post #: 1225545 posted 03/14/16 09:44 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the responses everyone
Will be getting it stripped down, have found a stock engine from a automatic VR that I'm getting put in for the time being.
Quick question as it's the first time doing a engine swap - I'll be changing the stock engine to manual, can I use the auto ECU?
Cheers
Edited by sixcentz (03/14/16 09:52 PM)
Generated in 0.217 seconds in which 0.201 seconds were spent on a total of 14 queries. Turbo powered.
