What goes up but wont go down?
maxash0775
Bakersfield, CA
Answer.... My 2nd gear. Now that my alternator issue is resolved my car has thrown me another curve ball. In the last 2 weeks out of no where my car will not let me downshift into second gear. I can shift up thru all the gears smoothly, but all of a sudden I have to be going like 10 miles an hour or it will grind. No changes to anything. The only other issue I have noticed is a squeeking when I press my clutch but that has been there for awhile. Any help please.
It is very common to see a worn out pedal assembly that will cause grinding issues and a squeeky pedal. If you get down there and look, you'll see that the clutch pedal isn't directly connected to the push rod for the clutch master cylinder. There is a tube that houses a connecting rod between the pedal and another bracket that actually attaches to the clutch master cylinder push rod. This rod and this bracket are keyed to each other and secured with a flat washer, lock washer, and nut. The key way can develope a "sloppiness" between the two parts and cause the pedal to have to be buried deeper to achieve the same level of disengagement of the pressure plate. The problem lies with the use of a stiffer clutch or when the play exceeds the available amount of pedal travel to allow the pressure plate to fully release the clutch disc. When this happens, you start to get grinding.
Look up +clutch +pedal +assembly -re:
Read the results regarding testing and repair of the assembly.
Shep Trans sells brass replacemant rod bushings that withstand the heat of welding the two pieces of the assembly back together in the right spot. The factory bushings are plastic and cannot withstand the heat.
Or you just have a worn out trans.
Cherry Hill, NJ
bad syncro's, it just happens. i couldn't downshift into 1st at all, i had to come to a complete stop to go into first. be careful because you don't want to lose second gear all together.
Wizardawd
Franklin, NC
My talon does that, I usually rev match, push it towards 1st then it goes in.
Wiz
maxash0775
Bakersfield, CA
No problem in any other gear up or down except second. Is there anyone who builds new and stronger pedal assemblies. I have had one break before in another car. Just trying to wait till bonus time so I can get it all done, but my car doesnt seem to want to wait. She has alreay waited 21 years i guess.
RedTwo
New Zealand
JNZ and Shepard? sell complete pedal assemblies or new clutch pedals. It's a bitch of a job by the looks of it though.
