chop91vr4
My first post got deleted I guess, So here's the run down fast like I traded for a crotch rocket I had love the car but don't have time for it, Lots of motor work done through the years most of the forum knows about this car and the prior owners, I had the engine all tuned up by a master mech who works on GVR4's runs strong, has a new 4 puck clutch VERY grabby, got a whole list I will attach. Bad the (ugly) normal sun fade to the roof & tops of the a couple doors & hood is black. The exterior good took the JDM front cover off stripped it down did repairs & repainted factory color with water born at the body shop I work at also imported in the original JDM fogs & fitted them & installed.Mech ugly needs trans work first to second grinds if not careful but will hold all the power you can give it. Looking for $4000 there's Alot of potential left in this one & I wanted to be the one who did it but just don't have the time right now. <img src="/ubbthreads/images/graemlins/bawling.gif" alt="" /> ALSO I did not paint the stuff under the hood.
List: 1991Galant VR-4 RARE JDM Front and Rear Bumpers w/custom lip & Turn signals
4 door sedan
All wheel drive
Turbocharged 4g63
Black Leather Interior
- Eagle Rods
- Wiesco Pistons
- Arp Fasteners & Head Studs
- 4 bolt rear
- Updated 1993 Headlights and Tail lights
- 60k miles on a fresh JDM 4G63, 200k+ on body
- Balance shafts eliminated, 4WS eliminated
- 15k miles on rebuilt tranny with a welded diff
- Coil on Plug ignition upgrade
- NGK BPR7ES plugs
- aftermarket fuel pressure regulator
- AEM Fuel rail
- manual boost controller (set@19psi)
- large front mount intercooler w/custom piping
- Tial BOV
- 3" turbo to 2.5” back with Thermal muffler
- K&N filter w/adapter pipe
- GM-MAF
- MAF Translator
- Ported EVO3 16G turbo
- Godspeed Header
- Godspeed down pipe
- 560cc injectors
- upgraded 255 fuel pump w/correct rewire
- battery relocated to the trunk
- 5-lug conversion
- urethane sub frame bushings
- Urethane Engine mounts
- new master cylinder, new slave cylinder with extended push rod
- HR lowering springs
- KYB adjustable struts
- Replaced oil return gaskets & Tube
- 300mm Momo steering wheel
- Manual seat belt conversion
- Boost Gauge & Narrowband a/f gauge in dual pillar pod
- Water Temp Gauge
- Short throw shifter
- Shift light W/ Digital Tach
- Slim Rad fan
- Oil cooler delete
- Full A/C delete
- FIAV Bypass
- Sony Clie Data logger
- Apex turbo timer/multi-function
- Just rebuilt throttle body full rebuild & cleaning & gasket
- Just rebuilt Biss, new screw & seal
- New knock sensor
- New O2 sensor
4 door sedan
All wheel drive
Turbocharged 4g63
- Eagle Rods
- Wiesco Pistons
- 4 bolt rear
- NGK BPR7ES plugs
- AEM Fuel rail
- Tial BOV
- GM-MAF
- MAF Translator
- Godspeed Header
- 560cc injectors
- 5-lug conversion
- Water Temp Gauge
- Slim Rad fan
- Oil cooler delete
- Full A/C delete
- FIAV Bypass
- New knock sensor
- New O2 sensor
