Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » JDM Headlights (wiring)
VR4GALANT42
Galant VR-4 org Post #: 140445 posted 10/07/04 12:15 PM     Remind Me!  Send Private Message   Edit Post
Anyone know the wiring?
| | | IP: (152.163.100.134) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 140451 posted 10/07/04 12:26 PM     Remind Me!  Send Private Message   Edit Post
Post deleted by blacksheep
Posts: 15470 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (207.108.41.190) | Report this post to a Moderator
VR4GALANT42
Galant VR-4 org Post #: 140453 posted 10/07/04 12:29 PM     Remind Me!  Send Private Message   Edit Post
Post deleted by Team Ducktape
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 140455 posted 10/07/04 12:35 PM     Remind Me!  Send Private Message   Edit Post
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140460 posted 10/07/04 12:45 PM     Remind Me!  Send Private Message   Edit Post
I'm sure there is more than one way to do it.
this is looking through the front of the passenger side headlight.
SteveW
484/1000 Kensington Grey - Running VERY well :-)
564/2000 Belize Green ~ SOLD
749/2000 Summit White ~ SOLD
1989 Chrysler Conquest TSi SHP ~ SOLD
2004 Saab 9-5 ARC ~ Daily Driver
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (162.18.75.92) | Report this post to a Moderator
VR4GALANT42
Galant VR-4 org Post #: 140486 posted 10/07/04 01:20 PM     Remind Me!  Send Private Message   Edit Post
So ignore the top wires. Thanks
| | | IP: (64.12.116.138) | Report this post to a Moderator
GalantVR4-1229
Galant VR-4 org Post #: 140492 posted 10/07/04 01:35 PM     Remind Me!  Send Private Message   Edit Post
Let me know if you find some changes.
If you know the wireing for the h4 bulb, I can add that too.
I just made this from notes I had when I did this myself.
Edited by GalantVR4-1229 (04/14/06 02:39 PM)
| | | IP: (68.57.55.46) | Report this post to a Moderator
GalantVR4-1229
Galant VR-4 org Post #: 140494 posted 10/07/04 01:39 PM     Remind Me!  Send Private Message   Edit Post
4 wire's fou!
although I'm sure there is more than one way to do it.
You sure you got JDM lights? The high beams in the center only have 2 wires while the outer high/low beams have 3. Or is there more then one kind of JDM lights?
GalantVR4-1229
Galant VR-4 org Post #: 140495 posted 10/07/04 01:41 PM     Remind Me!  Send Private Message   Edit Post
Oh and if you use relays, you can leave the stock connectors in the car. Just tap the correct wire into the relay as show in the diagram.
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140503 posted 10/07/04 02:16 PM     Remind Me!  Send Private Message   Edit Post
I've got JDM lights, however I know there are 3 different types. I've wired up 3 pairs in my buddies cars and all of them have worked fine just wiring the simple way like I have shown. I'm not very electronically inclined so I didn't really do any research, I just made sure I had power to power & ground to ground from the stock leads (using a multimeter of course). The way I have it shown will enable the high beams to light up while the low beams are still on (unlike stock). Is that how they work wired up like you have them shown? Also what is the benefit of having them wired up like you have them shown same as stock, different? Just curious.
EDIT: One other thing I noticed in your diagram is that you have an H4 and H3 bulb listed, I've never heard of any type of JDM headlight with an H3 bulb, as far as I know there are either dual H4's or an H4 and H1.
SteveW
Edited by mistaVR4 (10/07/04 02:37 PM)
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 140511 posted 10/07/04 02:43 PM     Remind Me!  Send Private Message   Edit Post
Mods - move Justin Millers post into how-to as a sticky! I would if I could!
crucible
Galant VR-4 org Post #: 140522 posted 10/07/04 03:04 PM     Remind Me!  Send Private Message   Edit Post
Im not sure thats correct
If you just cut the stock lite plugs and connected the wires to the JDMs, then the high/low switching will still be the same since you're still using the stock relay setup.Unless Im missing something in the sketch
Also, I don't recall having a 3rd wire on the inner(high beam) side on mine.The 3rd wire on the outer(lowbeam) is for an extra high beam I believe.You can tap the pos inner high beam wire to trigger the outer 3rd wire.
Not sure if that made any sense.Please correct
| | | IP: (198.8.4.11) | Report this post to a Moderator
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 140542 posted 10/07/04 04:17 PM     Remind Me!  Send Private Message   Edit Post
Make sure you use 10 gauge wire for everything. Solder all connections to ensure proper use... use some die-electric grease too. I'd say use a relay for each bulb, so four total. I would use 10 gauge wire for the ground, and while you could ground them to the battery, you can just ground them to the body.
This is how I am doing mine, but I said fuck the regular bulbs and went with 100w H1s, and 100/80W H4s... this combo will probably fry your stock harness beyond belief, but with relays and heavy duty wiring, you will have more than enough light when you are driving fast at night.
FWIW, I got all my wire, gold connectors, relays, fuses, shrinkwrap, EVERYTHING... from Parts Express. All said and done it was like $50 or so.
I got my bulbs(I went with Hellas) from Rally Lights for like $35.
You could get some gay HID/Xenon look-a-likes off Ebay, but that would be gay. Regular lights with the relays is more than enough.
One of these days I'll get a writeup done... but this should put you in the ballpark.
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3855 | From: Cypress, TX | Member Since: 08/07/02 | IP: (24.17.247.200) | Report this post to a Moderator
VR4GALANT42
Galant VR-4 org Post #: 140551 posted 10/07/04 04:44 PM     Remind Me!  Send Private Message   Edit Post
All done. I went the simple way(no relays). But now my high beams aren't working. I reversed the wires and still nothing. The bulbs must be blown. I'll let u know tomorrow. Thanks for the help.
| | | IP: (205.188.116.138) | Report this post to a Moderator
Romanova
Galant VR-4 org Post #: 140554 posted 10/07/04 04:50 PM     Remind Me!  Send Private Message   Edit Post
Remember, DO NOT TOUCH THE BULBS! Touch yourself all you want, just NOT THE BULBS. Wear gloves if you must touch them...
tyler
2016 Explorer PI
2006 LS430
2012 GX460
VR4GALANT42
Galant VR-4 org Post #: 140615 posted 10/07/04 08:10 PM     Remind Me!  Send Private Message   Edit Post
I sell auto parts 4 a living and tell people that all day.
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140647 posted 10/07/04 09:38 PM     Remind Me!  Send Private Message   Edit Post
Were they working before? You can tell if there blown just by looking at the inside of the light, the lighting element will be loose (shaking around).
Cruce: If the lights are wired like I have in my diagram both lights will be illuminated when the highbeams are on. I'm not sure why? Butmy guess would be because it's an H4 type bulb vs a 900x like stock, here's mine:
Justin: you use these new relays so you can run the higher wattage bulbs right? (like Tyler has explained) If not, why are they necessary? I thought about that to but since I run the same wattage H4/H1 setup as stock, the relays that already exist in the stock wiring do the trick just fine.
VR4GALANT42: you say ask so I will What have you done to your car?
SteveW
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (172.193.73.230) | Report this post to a Moderator
crucible
Galant VR-4 org Post #: 140677 posted 10/08/04 03:17 AM     Remind Me!  Send Private Message   Edit Post
Mista,
How could using different type bulbs change the stock sequence of relays?
Something was altered to keep both lites on is my guess
Not trying to bust balls, just curious how you got there
Cruce
| | | IP: (67.87.121.43) | Report this post to a Moderator
Romanova
Galant VR-4 org Post #: 140693 posted 10/08/04 07:14 AM     Remind Me!  Send Private Message   Edit Post
I believe there is only one relay stock. That is no good for highwattage bulbs.
tyler
2016 Explorer PI
2006 LS430
2012 GX460
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140717 posted 10/08/04 08:24 AM     Remind Me!  Send Private Message   Edit Post
Mista,
Cruce
It must have something to do with the 3 prongs on the H4 bulb. So if I were to hook the red with blue stripe to the top prong instead of the side prong it might act like stock? I never tried that because I liked the way it is, I suppose I could try it the other way just to see what happens. Another possibility is the H1 light, the rubber cover that plugs into the H1 light has 2 prongs but the light itself only has 1, I'm thinking there might be a power or even more likely a ground return through the stock bulb which has 2 prongs that triggers a relay to shut off the lowbeam headlight when you put highbeams on, (does any of that make sense?) It seems strange to me as well but those are the only possibility's I can think of. If you wire your JDM headlights the way I have shown them both will light up. Give it a try and let me know what happens, it would be interesting to see if it works in you car also.
SteveW
keydiver
Galant VR-4 org Post #: 140748 posted 10/08/04 10:16 AM     Remind Me!  Send Private Message   Edit Post
Personally, I would NOT hook it up with just 2 of the 3 terminals being used. The unused terminal is the common ground for the 2 filaments. What you are doing is running the two filaments in series, so you are only getting 1/2 the brightness you should.
I've been through this with several members, and using relays is the only right way to do it.
| | | IP: (65.11.93.11) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 140755 posted 10/08/04 10:26 AM     Remind Me!  Send Private Message   Edit Post
nice grille
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140756 posted 10/08/04 10:27 AM     Remind Me!  Send Private Message   Edit Post
Jeff,
Couldn't I just run the unused terminal to a ground somewhere and keep the stock relay setup? It seems even more strange because those lights are pretty dam bright even with the stock wattage bulb I can't imagine them being any brighter unless I upgraded wattage? Also, If I were to ground the top terminal that would then cause the lowbeam to shut off when highbeams are turned on wouldn't it?
So you basically saying that using Justins method even with the stock wattage bulbs is better? why? As I said I don't really know a whole lot about electrical systems but I don't understand why this would be so wrong. Could you please explain in more detail to help me(us) understand a little better? I'd appreciate it.
SteveW
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 140757 posted 10/08/04 10:30 AM     Remind Me!  Send Private Message   Edit Post
nice grille
Not bad eh? Pricy, but more than worth it
SteveW
Minjin
Galant VR-4 org Post #: 140784 posted 10/08/04 11:27 AM     Remind Me!  Send Private Message   Edit Post
I'll move the thread after the conversation dies.
Mark
| | | IP: (24.54.215.79) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.076 seconds in which 0.028 seconds were spent on a total of 14 queries. Turbo powered.
