Galant VR-4 Forums » Marketplace » Parts For Sale » FS: Head Porting Services NEW DEAL!!!
BOOSTIN HARD
Galant VR-4 org Post #: 354262 posted 06/28/06 11:34 AM     Remind Me!  Send Private Message   Edit Post
Starting to set up package deals. You can also just order individual parts from me or just have me port your head. Its totally up to you. All of these prices are for 4g63's.
Mitsu Valve packages
E-LOY Performance stainless valves
1mm over intake valves
.5mm over exhaust valves
1 set=16 valves 232.00
Super Tech Valves
1mm over exhaust valves which are inconel(can take very high heat)
1 set=16 valves 332.00
Bronze valve guides=set of 16 72.00or4.50 each
Set of 16 valves seals=23.00
set of 32 valve locks=25.00
Super Tech single valve springs=145.00
Super Tech single valve springs with Ti retainers=335.00
Super Tech dual valve springs with spring seats and Ti retainers=415.00
Machine work is as follows, all done by Class One Performance Engines by Terry Thomas
R&R Guides and hone to ID size=88.00
Valve Job-Radius cut seats,2 angle valves as needed, mill deck surface and chamfer chamber's, finish cleaned and assembled, springs installed, seals installed, tips of valves cut to remain in specs=250.00
Line hone cam Journal's-varies by the head=75.00-100.00
All this work can be done or you can pick and choose what you want done. My porting work is 600.00. If you are going to send me your own parts they have to be quality parts and in good shape. PM me with any questions.
Edited by BOOSTIN HARD (10/23/07 08:27 AM)
| | | IP: (216.203.116.104) | Report this post to a Moderator
Jonvr4
Galant VR-4 org Post #: 355232 posted 06/30/06 10:31 PM     Remind Me!  Send Private Message   Edit Post
Do you have flow #'s? The porting looks great, and not trying to discredit! But if you had #'s I am pretty sure I am interested.
| | | IP: (71.33.137.236) | Report this post to a Moderator
CO VR4
Galant VR-4 org Post #: 357283 posted 07/08/06 06:28 PM     Remind Me!  Send Private Message   Edit Post
I could shave in those polished ports
Everyone is entitled to their own opinion, but not their own facts.
Posts: 2019 | From: Colorado | Member Since: 07/13/02 | IP: (67.161.153.204) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 357446 posted 07/09/06 02:55 PM     Remind Me!  Send Private Message   Edit Post
Looks good and look forward to having you p&p a few heads I need worked on.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-202M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-88M
2017 VW Passat 1.8L Turbo-23M
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (24.12.7.112) | Report this post to a Moderator
gvr4592
Galant VR-4 org Post #: 358129 posted 07/11/06 01:26 PM     Remind Me!  Send Private Message   Edit Post
What machine work is done for $250?
| | | IP: (24.17.55.150) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 358130 posted 07/11/06 01:29 PM     Remind Me!  Send Private Message   Edit Post
Mill the head, three angle valve job, ream the guides after I install them, and fully assembled.
Spoolin
Galant VR-4 org Post #: 358401 posted 07/12/06 09:46 AM     Remind Me!  Send Private Message   Edit Post
Also would be interested. Looks amazing, do you flow bench test them at completion?
| | | IP: (192.249.47.8) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 358457 posted 07/12/06 12:19 PM     Remind Me!  Send Private Message   Edit Post
I have flowed several heads after I have ported them, and all have been very close to one another. To match each port exactly would take forever and would cost quite a bit more. I can however do it if you would like. The cost would be 25.00 to 30.00 dollars an hour and I have no idea of how long it would take, because if I take a little to much out of one then I would have to go take that much more out of the other ports and if on the last port I take to much out I would have to go back and fix the other ones. All in all it really isn't that critical to have each port an exact match. If they are +or- 1 to 2 % I am happy with that. I have had no complaints yet.
BOOSTIN HARD
Galant VR-4 org Post #: 360225 posted 07/18/06 09:54 AM     Remind Me!  Send Private Message   Edit Post
Post deleted by BOOSTIN HARD
OldHairyBastard
1/0000
Galant VR-4 org Post #: 368694 posted 08/10/06 04:49 PM     Remind Me!  Send Private Message   Edit Post
I gave him a set of Toyota heads and an intake to do. I will post pics when it is completed but I told him no hurry so it might not be for a little while.
Doug
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (206.82.153.207) | Report this post to a Moderator
OldHairyBastard
1/0000
Galant VR-4 org Post #: 369830 posted 08/14/06 11:22 AM     Remind Me!  Send Private Message   Edit Post
He has already started on one head and brought it over yesterday. It looks really good. If anyone is out there and needs a P&P he is your man to take it to. He is a stand up guy and you will have no issues with BS. What he tells you is what it is and he is ready to work!!!!
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (206.82.153.206) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 373944 posted 08/24/06 11:11 AM     Remind Me!  Send Private Message   Edit Post
New parts added.
TrendSetter
Galant VR-4 org Post #: 377336 posted 09/01/06 10:58 AM     Remind Me!  Send Private Message   Edit Post
what kind of numbers are you getting?
| | | IP: (64.128.134.242) | Report this post to a Moderator
Jonvr4
Galant VR-4 org Post #: 377337 posted 09/01/06 11:01 AM     Remind Me!  Send Private Message   Edit Post
Don't bother asking. There was a HUGE discussion about this. Just search, and you will see you asked a worthless question. Not being a dick either, sorry if it sounds that way!
| | | IP: (4.42.202.200) | Report this post to a Moderator
TrendSetter
Galant VR-4 org Post #: 377344 posted 09/01/06 11:22 AM     Remind Me!  Send Private Message   Edit Post
just found the thread. i got a good laugh thanks.
whats the setup the head in those pictures is going on? has it run yet? what kind of power/et? anyspecifics other than 'its shiney' ?
Edited by TrendSetter (09/01/06 11:24 AM)
BOOSTIN HARD
Galant VR-4 org Post #: 377366 posted 09/01/06 12:25 PM     Remind Me!  Send Private Message   Edit Post
42R, 2.3, air to water IC, Driven Innovation intake manifold, No numbers yet maybe in the next two weeks.
BOOSTIN HARD
Galant VR-4 org Post #: 377374 posted 09/01/06 12:38 PM     Remind Me!  Send Private Message   Edit Post
Yes I do.
BOOSTIN HARD
Galant VR-4 org Post #: 386162 posted 09/25/06 02:56 PM     Remind Me!  Send Private Message   Edit Post
CmanorVr4
Member +++
962/1000
Galant VR-4 org Post #: 399669 posted 10/28/06 10:47 PM     Remind Me!  Send Private Message   Edit Post
PM sent!!!
IRONMAN aka 'Tony Starks'
Summit White the fastest color!!!!!
Posts: 789 | From: Cortlandt Manor,NY | Member Since: 11/09/04 | IP: (205.188.117.72) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 407994 posted 11/17/06 02:05 PM     Remind Me!  Send Private Message   Edit Post
Hertz can you make this a sticky so it doesn't get deleted every month. Thanks buddy
Assmilk Pearl
Galant VR-4 org Post #: 407996 posted 11/17/06 02:07 PM     Remind Me!  Send Private Message   Edit Post
So you were able to get this thread back!
-mitsuturbo
Posts: 18893 | From: Flemington, NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
BOOSTIN HARD
Galant VR-4 org Post #: 407998 posted 11/17/06 02:09 PM     Remind Me!  Send Private Message   Edit Post
I just went back and found it by looking on my last posts. It just keeps getting knocked out of the sticky.
Doctor_D
Member +
Galant VR-4 org Post #: 408015 posted 11/17/06 02:29 PM     Remind Me!  Send Private Message   Edit Post
pm me more info, need a head ported
email: [email protected]
Business email: [email protected]
573/2000 (Summit White)
Posts: 265 | From: Niles, Illinois | Member Since: 11/16/06 | IP: (209.254.194.206) | Report this post to a Moderator
CmanorVr4
Member +++
962/1000
Galant VR-4 org Post #: 413193 posted 12/02/06 06:55 AM     Remind Me!  Send Private Message   Edit Post
You have a PM!
Posts: 789 | From: Cortlandt Manor,NY | Member Since: 11/09/04 | IP: (167.206.158.195) | Report this post to a Moderator
VR4MeSoon
Galant VR-4 org Post #: 492809 posted 06/16/07 04:54 AM     Remind Me!  Send Private Message   Edit Post
Hey I am interested in how much good it will do to have my 14b ported and if it is even worth the money? Would it be better just to wait and upgrade my turbo when I can afford it... in like a billion year seeing how this stroker build is going to kill my wallet.
| | | IP: (75.30.113.169) | Report this post to a Moderator
Pages: 1 | 2
4 registered and 17 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Rating: *****
Generated in 0.092 seconds in which 0.06 seconds were spent on a total of 14 queries. Turbo powered.
