yeti
Main questions are I need to drain my gas tank of e85 and clean fuel pump/injectors, put in 91 and stock turbo and injectors but keep whinebro in, convert dsmlink back to stock, except for fuel pressure.
I know I should break the car in on gasoline but I know there's gonna be some exd leftover inthere.
Should I break in on e85?
Also upon first start up should I drive around the block,rev the engine, idle for 30 mins, go do hot laps?
And then change oil after 500-1000 miles and then its broken in
