FS: VR4 front bumper lip **** $210 Ship ****
dustyduff
Mantua, NJ
The lip was designed to work with USDM and JDM bumpers. The link at the top of the thread shows the lip on cars with both bumper types.
Jordangvr4
Nassau,NYC.
Quoting jcgalntvr4-244:
Will this work on the AMG Bumper? if so Ill take one.
Cheers,
JC
No, will not work on the AMG
raptorWagon
Oak Harbor, WA
Cheers,
JC
I'll trade you bumpers so you can use the lip... /ubbthreads/images/graemlins/grin.gif
just kidding.
boostx
Orlando, FL
The price is going to be $235. This is a bit cheaper that the original set because of different materials being used.
Why is it 2 piece? And why doesnt it line up? What are u supposed to do? Glue them together or what?
Brunoboy
San Bruno,CA Home of SFO
It's two pieces for cutting shipping cost and each side is a bit longer due to some sagging bumpers, and it's common sense, double sided tape, maybe a screw on the rear, make it work.
They could be screwed together or just bonded with epoxy. As was said cheaper on boxes/packing materials and also shipping. Also when John called me about this project and he said the original was cut I was kind of glad. The USDM and JDM bumpers aren't the same physical size and this lets the USDM bumpers use the JDM lip as well as the extra takes up for sagging etc.
Also if you look close you'll see that one side is stepped back behind the other for thsi reason. When I install mine I plan on cutting out an aluminum doubler from 1/8 inch to place above the urethane of the JDM bumper with rivnuts installed so I can drill through the lip, bumper then aluminum and when there drilled install the rivnuts and then use machine screws to secure this extra tight before paint. Having a piece of aluminum will also assure a flat level foundation for everything. For those of you thats never heard of a rivnut run by harbor freight.
click me
they also have 100 pack of replacements for 10 bucks each.
How they work the aluminum rivnut or nutsert is screwed on to the puller. You stick this in the correct size drilled hole and then squeeze like a rivet but it doesn't pop off. You then unthread the puller and you have a perfectly threaded hole in a piece of thin aluminum. There's thousands of these on every aircraft in the air right now. The first set of aviation ones I got were hundreds I almost had a heart attack when I saw these at harbor freight and bought every package they had. Sorry these are all standard threaded ones no metric. /ubbthreads/images/graemlins/banghead.gif
Tre3zy
South San Francisco, CA
Quoting brunoboy:
/ubbthreads/images/graemlins/rofl.gif double sided tape? are you kidding me?
boostx
Orlando, FL
On each side of the bumper right in front of the wheel there is two holes that a metal bracket is use as part of the bumper support. Those two holes can be used to bolt up the lip. Two additional hole will be needed one near the center. (See the pic with the red arrows)
