Hello I have been thinking about selling the auto stuff I have. It will be everything you need to make your car an automatic, minus the front axles. So here goes:
I have well over $1200 into this stuff and countless hours getting the wiring ready:
Parts to make your 1gDSM/Galant vr4 an automatic:
-91+ automatic Trans and tcase around 100k on both
-4 bolt auto rear with axles and cups
-IPT Torque converter from Mark @ AMS never used just installed 4500rpm stall (new)
-Starter Plate (new), dual flex plates (1 plate new), rings (new), engine mounts, shifter bases and cables
-Wiring to hook up to car, Two TCU trans controlers.
I will take $800 for everything picked up Grafton WI, way less then what I have into the parts. I will not seperate and I won't ship the stuff.First come first served.
Thanks,
Rob
Thanks,
Rob
