4WS Delete (Which Lines to Cap Off?)
I have seen past suggestions on using 2 -6AN adapters (Earl's PN991954) and 2 -6AN Caps to block off the rear steering rack before. I like the idea because you don't have to cut up and weld the rack shut, like if I don't sell my car it could easily be replaced. But what never gets mentioned is which exact lines do you use the adapters/caps to block off? The fittings on the oem long RWS pressure lines look similar to the adapters that you need but I am not quite sure. If somebody would circle the actual lines and where to cap them, that would make it a lot easier
-Front Rack
-Rear Rack
tsiboy
Los Angeles, Ca
the lines are usually disconnected at the front rack and removed, then the AN adapters are used on the rack itself. i have two extra caps (592906ERL) if you need them, just pay for the shipping and they are yours, then you would only need to order the adapters.
besso two lines on the front power steering rack, the pic isnt showing the rack or im just blind. if you look under the car at the rack you should be able to see which ones need to be blocked. as far as the rear you will need to weld them shut I believe (i planned on just capping it off but it was a PITA so i ripped it all out and put a 4bolt in), also the reservoir for the power steering has 2 nipples that need to be blocked or try using a 2g reservoir (i dunno if the cap w/ sensor fits the 2g) good luck that sh*t sucks.
crap pic i found of the front rack
quote from another thread, good to know im gonna pick one up.
"The power steering fluid canister off the ggsx and regular galants works great"
BoostedAWD91
Danville,Pa
Quoting tsiboy:
if he doesnt take them ill take the two plugs for the rear lines on the front rack
jepherz
KC, Missouri
Yeah, you need to cap them off at the right. If you trace lines 46973b and 46973c forward to the rack, you will see which two you need to cap off.
Kenny_Kline
Seekonk, MA
I did a 4wd delete but also at the same time, I installed a manual front rack. I cut out all the power steering lines.
Correct me if I am wrong but doesnt the rack in the rear press the control arms 2-3 degrees and the flex is in the control arm bushings? Simply put, I dont have to brace anything in the back to keep the tires from turning, correct?
I believe once the rear rack is removed it will not move /ubbthreads/images/graemlins/dunno.gif
jepherz
KC, Missouri
Yes, it's pressing against bushings in the rear, but when you remove the rack it becomes "passive" just like any DSM. Some people do fix them solid though.
Kenny_Kline
Seekonk, MA
Well I left the rack installed. Just no lines going to it.
To take the rack out, I think you have to drop the subframe...
Quoting Kenny_Kline:
I didnt just rip it out
